  2. Mixed-Signal Design
  3. Virtuoso: cloning vs unit cell
  • Subscribers 64
  • Views 13254
AshutoshLayout
AshutoshLayout over 5 years ago
Can anyone confirm for the large layout database, will the top level hierarchy with unit cell kind of instances repeated 1000s of time load faster or the cloned synchronous groups repeated the same amount of time load faster?
I know that if we use unit cells, we loose the xl-connectivity and there are other demerits of it. But, only from a layout loading point of view which would load faster and why?
    If there are a very large number of instances/objects which are cloned, then I would expect the hierarchical approach to be faster to load - mainly because there would be fewer objects in the resulting…
    If there are a very large number of instances/objects which are cloned, then I would expect the hierarchical approach to be faster to load - mainly because there would be fewer objects in the resulting layout. If the unit cell has (say) 20 instances and 30 shapes (say), then 1,000 clones means you have 20,000 instances and 30,000 shapes in the cellView. If you have an actual unit cell, then there are only 1,000 instances plus 20 instances plus 30 shapes to load overall - so much less data.
    If there are relatively few instances/shapes within the cloned unit then the difference is going to be smaller.
    Note that the hierarchical approach may not be that bad because you can use transparent instances to still consider the connectivity through the hierarchy.
