  2. Mixed-Signal Design
  3. Does xrun support connection module between nettype and...
  • Subscribers 64
  • Views 2083
Does xrun support connection module between nettype and logic?
RZAQA
RZAQA over 4 years ago
I have a design in which VDD is connected to the input of a custom logic cell, e.g.
NAND2 I_NAND2(.VDD(VDD), .VSS(VSS), .in1(VDD), , in2(net1), .out(net2));
the NAND2 cell is using a dms model, e.g:
module NAND2(VDD,VSS,in1,in2,out);
  inout EEnet VDD;
  inout EEnet VSS;
  input wire in1, in2;
  output wire out;
endmodule
In this case, I will need a EEnet to logic connection module, looks like EE_pkg doesn't come with EEnet_2_L.svams by default,
I following the EEnet_2_E.svams and implement a EEnet_2_L.svams and put into compile but it doesn't perform the auto insertion at all.
I wonder does "EEnet" or even "nettype" to L connection module insertion supported in xrun?
Rui
    There is an enhancement request already asking for this: AVSREQ-120941. I suggest you contact customer support and request a duplicate. I believe the idea was to get this into XCELIUM21.03 but that doesn't seem to have quite happened (and currently XCELIUM21.03 is incompatible with Virtuoso anyway until later this year).
