  2. Mixed-Signal Design
  3. Spice to Spectre conversion
  • Replies 17
  • Subscribers 64
  • Views 24195
sram17
sram17 over 5 years ago
Hi Experts - I'm a novice trying to convert a subcircuit from HSPICE to Spectre. I am not sure how Spectre refers to node voltages or uses user-defined functions. Could you please let me know if this conversion is valid? Help is very much appreciated!
Shriram
SPICE:
.SUBCKT dom n1 n2 p1
.param alpha = 'a1'
* user-defined function
.param f1(x,y) = '0.5* alpha*x*y
*current source is function of Voltage at p1 and Voltage difference across n1 and n2
G_p1 0 p1 CUR = '-f1(V(p1),2) - V(n1,n2)'
.ENDS dom
Spectre:
subckt dom (n1 n2 p1)
parameters alpha = a1
// user-defined function; need to pass alpha as a variable (different from SPICE)
real f1(real x, real y, real alpha) {
return 0.5*alpha*x*y
// Is this a valid way to define the current source using node voltages and user-defined function in Spectre?
G_p1 0 p1 bsource i=-f1(v(p1),2,alpha)-v(n1,n2)
ends dom
    ShawnLogan over 5 years ago
    Dear Shriram,
    Did you happen to check the spectre manual or the On-line support partal? If not, the following document details the syntax and scope of user defined functions:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=spectreref.xml&title=Spectre%20Circuit%20Simulator%20Reference%20--%20Other%20Simulation%20Topics%20-%20User%20Defined%20Functions%20(functions)&hash=pgfId-1068879&c_version=20.1&path=spectreref/spectreref20.1/chap4.html#pgfId-1068879
    Otherwise, from the UNIX prompt, type:
    spectre -h expressions
    and
    spectre -h bsource
    The short answer is your syntax does not conform with that required by spectre. spectre uses parenthesis to enclose node names. As an example from the spectre -h output,
    Voltage-controlled current source
             vsrc (n1 n2) resistor r=100k
             vccs1 (n3 n4) bsource i=v(n1,n2)/2000.0
    I hope this provides enough information and I understood your questions Shriram!
    Shawn
  • sram17
    sram17 over 5 years ago in reply to ShawnLogan
    Thanks a lot, Shawn! I noticed the paranthesis, however, ADE somehow did not throw up a syntax error when I saved the Spectre file without paranthesis, so I assumed they were optional.
    It is still not clear to me based on the examples if I am allowed to send a node voltage as a variable to a user-defined function in bsource and have the sub-circuit behave as it does in SPICE.
    Are you suggesting that it is correct?
    Thanks again,
    Shriram
    ShawnLogan over 5 years ago in reply to sram17
    Dear Shriram,
    Perhaps I am not understanding your question correctly and I apologize if I am not!
    However, in the example I provided, v(n1,n2) represents the voltages between circuit nodes n1 and n2 and is used in the bsource  function v(n1,n2)/2000.0 as its current. Are you suggesting defining the voltage v(n1,n2) as a separate distinct variable? In lieu of that, perhaps you can just define a voltage net in your circuit, say vdelta, as the difference between node voltages n1 and n2, and then use voltage vdelta in your expression, for example i=v(vdelta)/2000.0.
    Did I manage to understand your comment?
    Shawn
  • sram17
    Hi Shawn - I think we are converging on the same item. I have reduced the complexity of my dependent current source for the purpose of the forum posting. My current source is a somewhat complicated function of not only the voltage difference v(n1,n2), but also a node voltage v(p1). I have tried to express that as f1(v(p1)), with a user-defined function. I was trying to understand if this is a valid way to define a complicated functional relationship in Spectre for a dependent-current source. Hope my question is clear.
    Thanks again for your time and comments!
    Shriram
  • sram17
    sram17 over 5 years ago in reply to sram17
    Sorry, maybe I messed up and wrote f1(v(p1)) when clearly f1 has 3 variables. So, the correct expression should have been:
    G_p1 0 p1 bsource i=-f1(v(p1), 2, alpha)-v(n1,n2)
    where x=v(p1) and y=2
  • sram17
    I fixed the expressions in the original post. Sorry about the confusion!
    Dear Shiram,
    Did you examine the examples when you type spectre -h expressions at the UNIX command line? If you examined it, it suggest you type spectre -h function for additional information on calling your own functions in expressions. Typing this at the UNIX prompt yiedls:
    "$ spectre -h functions
    User Defined Functions
    Spectre's user-defined function capability allows you to build upon the provided set of built-in mathematical and trigonometric functions. You can write
    your own functions, and call these functions from within any expression. The syntax for calling a user-defined function is the same as the syntax for
    calling a built-in algebraic or trigonometric function. Note that user-defined functions must be defined before they are referenced (called). Arguments
    to user-defined functions will be taken as real values, and the functions will return real values. A user-defined function may contain only a single
    statement in braces and this statement must return an expression (which will typically be an expression involving the function arguments). The return
    expression may reference the built in parameters `temp' and `tnom'. User-defined functions must be declared at the top level only, and must not be
    declared within subcircuits. User-defined functions may be called from anywhere that an expressions can be currently used in Spectre. User-defined
    functions may call other functions (both user-defined and built-in), however any user-defined function will need to be declared before it can be called.
    User-defined functions can override built-in mathematical and trigonometric functions.
    NOTE: Only real values for arguments and return values are supported in this release.
    See `spectre -h expressions' for a list of built-in algebraic and trigonometric functions
    Synopsis:
    real myfunc( [real arg1, ...real argn] ) {
       return <expr of arg1..argn>
    Examples:
    real myfunc( real a, real b ) {
        return a+b*2+sqrt(a*sin(b));
    An example of a function calling a previously defined function follows
    real yourfunc( real a, real b ) {
        return a+b*myfunc(a,b);     // call "myfunc"
    The final example shows how a user-defined function may be called from an expression in the Spectre netlist:
    r1 (1 0) resistor r=myfunc(2.0, 4.5)"
    Does this help?
    Shawn
  • sram17
    Hi Shawn - I read all that already. There are a few suspicious things. First, it says one cannot define functions inside sub-circuits, which kind of seems quite problematic, since we work at different levels of abstraction and a subcircuit allows one that flexibility. None of the examples use node voltages as inputs to user functions.
    My question can be stated as below:
    Can one use node-voltages as inputs to a user-defined function for the purposes of defining a controlled current source inside a sub-circuit in Spectre?
    Shriram
    Dear Shihram,
    I think you may have overlooked a statement in the help articles I suggested....you added an additional constraint that I either overlooked or you did not include when you noted concerning a subcircuit...:
    From the help article:
    "User-defined functions must be  declared within subcircuits."
    Shawn
  • sram17
    Hi Shawn - not sure where that is. This is what I see:
    Also, do you have any idea about whether one can pass a node voltage as an argument?
