  2. Mixed-Signal Design
  3. question on dyn_mosv check
  • Subscribers 64
  • Views 11239
RZAQA
RZAQA over 5 years ago
Hi
I am using  "dyn_mosv" to look for voltage violations on mosfet during transient simulation. I need help understanding the report.
In the webpage report, column "Model Name", it shows a random hierarchical path rather than cell name or device name. same issue exists in "Gate Name/ Drain Name" columns
Also I found it reports violations only once even there are multiple occurrences, and I didn't put "sample=extreme" parameter on command in those cases.
attached is my report screenshot
Rui
