  2. Mixed-Signal Design
  3. Problem with understanding the noise integration
  • Subscribers 64
  • Views 15331
Phong Phan
Phong Phan over 5 years ago
Greetings,
I want to understand the total integrated output noise of my circuit. Using "Results > Direct Plot > Main Form" I can get the expression for plotting the squared of my output noise (which I believe to be the Power spectral density):
(getData("out" ?result "noise")**2)
This will give me the following graph:
I think by integrating this waveform and then take the square root should give me the rms value of my integrated output noise. (Assuming similar frequency range setup)
sqrt(integ((getData("out" ?result "noise")**2) 0.1 1k " " ))
(Which is indeed agrees with the value given in my Noise Summary.)
To my understanding, integrating the graph above from 1mHz to 1Hz should give a much larger result compared to the range from 1Hz to 1kHz (here there's almost nothing). However the result is very contradictory to my understanding:
sqrt(integ((getData("out" ?result "noise")**2) 1m 1 " " )) = 6.205E-6
sqrt(integ((getData("out" ?result "noise")**2) 1 1k " " )) = 10.4E-6
Here's the attached .vcsv file exported from my noise curve.
I'm still learning myself so any feedback would be extremely appreciated.
Thanks a lot!
    You're being confused by the log x-axis. Try plotting on a linear x-axis (right mouse button over the x-axis allows you to change it). The bandwidth of the second integration is 1000 times higher than…
    You're being confused by the log x-axis. Try plotting on a linear x-axis (right mouse button over the x-axis allows you to change it). The bandwidth of the second integration is 1000 times higher than the first integration, and so whilst the magnitude is smaller, you have a much larger x-range to integrate over. A narrow peak on a log x-axis looks big, but it's fairly insignificant over the wider range.
  • Phong Phan
    Phong Phan over 5 years ago in reply to Andrew Beckett
    Thank you Andrew! That's very silly of me for not realizing.
