  2. Mixed-Signal Design
  3. inconsistent xmvlog failure in Virtuoso AMS setup (assembler...
  • Subscribers 64
  • Views 16034
inconsistent xmvlog failure in Virtuoso AMS setup (assembler failure)
monglebest2022
monglebest2022 over 4 years ago
Hi I create a virtuoso AMSDMV setup bench with config view/AMS simulator/IE card global default 1.8V setup.
The simulation will failed one time and successfully complete another time. The error reported when it's failed is
#### error information ##########
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.4/1/trans_AMSDMV/netlist/digital/netlist.vams,8|15): library 'tsmcN65' is not defined.
module worklib.crus_dnwpw_dio:schematic
errors: 0, warnings: 0
#### end of error information ##########
I don't understand why it's so in-consistent. Please see the attached netlister.log files for difference. I also have the whole netlist folder attached. Can someone tell me why the AMSDMV failed sometimes and successfully in another time? It's too hard for me to debug it, please help.
####### successful nestlister.log file #####
Begin Netlisting Oct 25 15:35:57 2021
INFO (AMS-2052): The value '1000' specified for the variable 'hnlMaxLineLength'
in the file '.simrc'
might introduce syntax errors in the generated netlist.
Therefore, the default value '4000' will be used.
INFO (VLOGNET-60): The stimulus name mapped table will not be printed in the
"/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.3/1/trans_AMSDMV/netlist/digital/testfixture.verilog" file. To print the stimulus name mapped table, set
simVerilogPrintStimulusNameMappingTable = t either in CIW or the .simrc file
before invoking Verilog netlister.
INFO (VLOGNET-62): Database internal net names will be printed for floating
instance ports. To prevent
them from being printed, set
simVerilogProcessNullPorts = t either in CIW or
the .simrc file.
INFO (VLOGNET-64): All cellviews in the design will be printed in the Netlist
Configuration list.
If you want to print only those cellviews that need to be
re-netlisted in the
list, set simVerilogIncrementalNetlistConfigList = t either
in CIW or the
.simrc file.
INFO (VLOGNET-68): The initial state of stimulus of all inout pins is set to
"z". To get inout
pins with initial state of "0", set
hnlVerilogIOInitStimulusStr = "0"
either in CIW or the .simrc file.
WARNING (OSSHNL-335): Design configuration has changed since last netlisting
session in this run
directory. Netlist(s) from last session cannot be reused for
incremental
netlisting. Therefore, re-netlisting the design.
INFO (VLOGNET-118): Using connection by name (explicit connections) for all
stopping and
non-stopping cells.
WARNING (VLOGNET-110): The cell
'j055_micbias_cohen_add/tb_test_AMSDMV/schematic' has no ports. Make sure that
this was the intended
design.
INFO (VLOGNET-126): ---------- Beginning netlist configuration information
(incremental data only)
CELL NAME VIEW NAME NOTE
nch_hvi25 spectre *Stopping View*
vcvs spectre *Stopping View*
inv_25_dnwod33 systemVerilog *Stopping View*
res spectre *Stopping View*
vdc spectre *Stopping View*
cap spectre *Stopping View*
vpwl spectre *Stopping View*
tb_test_AMSDMV schematic
---------- End of netlist configuration information ----------
session in this run
incremental
Running netlist assembly..
End netlisting Oct 25 15:36:15 2021
######## end of successful netlister.log file ###################
####### failed nestlister.log file #####
Begin Netlisting Oct 25 16:01:42 2021
"/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/testfixture.verilog" file. To print the stimulus name mapped table, set
the .simrc file.
Configuration list.
re-netlisted in the
in CIW or the
.simrc file.
"z". To get inout
WARNING (OSSHNL-159): The primitive,
'j055_micbias_cohen_add/inv_25_dnwod33/systemVerilog', has been updated since
the last netlisting session
in this current run directory. Therefore,
re-netlisting all cell views where
this primitive is instantiated.
stopping and
non-stopping cells.
design.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,8|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,35|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,61|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,88|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,107|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,126|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,145|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,171|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,327|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,355|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,388|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,449|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,468|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,487|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,506|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,531|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,556|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,582|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,741|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,819|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,838|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,866|17): library 'j055_lvls' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,978|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1003|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1030|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1091|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1110|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1130|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1181|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1206|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1232|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1288|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1308|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1357|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1419|17): library 'j055_lvls' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1530|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1552|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1692|17): library 'j055_vcas' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1775|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1800|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1820|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1853|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1887|17): library 'j055_lvls' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1918|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1945|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1970|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,1995|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2020|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2045|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2070|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2096|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2120|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2146|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2173|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2192|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2211|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2230|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2249|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2268|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2287|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2312|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2337|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2356|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2381|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2406|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2431|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2450|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2469|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2494|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2519|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2538|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2560|15): library 'tsmcN65' is not defined.
xmvlog: *E,WKLNDF (/sims/cohen/results/gfan/trunk/adexlResults/j055_micbias_cohen_add/tb_test_AMSDMV/maestro_sv/results/maestro/Interactive.6/1/trans_AMSDMV/netlist/digital/netlist.vams,2594|17): library 'j055_lvls' is not defined.
xrun: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 1).
######## end of failed netlister.log file ###################
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/92/netlist_5F00_interactive6_5F00_error.tar.gz
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/92/netlist_5F00_interactive3_5F00_success.tar.gz
  • monglebest2022
    In the failed netlist folder attached, there is a file under digital/netlist.vams exist but successful run doesn't contain this file at all. It's this file report the above "library XXX is not defined" error.
    AMS DMV is end-of-lifed, but it might be easiest to debug this via customer support.
  • monglebest2022
    monglebest2022 over 4 years ago in reply to Andrew Beckett
    Thanks, Andrew. I filed a customer support case (46569711) and the issue has been resolved.
    • Set the below variable in your .cdsinit file and restart virtuoso. This will trigger full netlisting.
      _amsOSSEnableNetlistAllForFirst=t
    May I know what is the latest tool for Analog-mixed signal simulation in Virtuoso?
    Andrew Beckett over 4 years ago in reply to monglebest2022
    AMS simulation can be run from ADE, as has been possible for 20 years or so. AMS DMV was specifically for model validation, and that can also be achieved in ADE Assembler, for example.
