  2. Mixed-Signal Design
  3. Can I pass a variable from ADE Explorer into a systemverilog...
  • Subscribers 64
  • Views 11407
Can I pass a variable from ADE Explorer into a systemverilog module as an integer?
BillH314
BillH314 over 4 years ago
I'd like to do some variable sweeps in which I declare a variable in ADE Explorer and have that variable pass directly into a systemverilog module to change some of the bit widths.  I'd like to set an integer bit width to a variable using hierarchical syntax.   Does anyone know if there's a way to do this?
Here's a couple of my failed attempts:
ATTEMPT #1
// Inside systemverilog module:
localparam NUM_BITS = cds_globals.NUM_BITS_VAR;
wire [NUM_BITS:0] my_wire;
// In ADE Explorer:
NUM_BITS_VAR set to 2 in ADE Explorer
==> result xmelab: *E,NOTDOT (<path name to verilog file>): Hierarchical name ('cds_globals.NUM_BITS_VAR') not allowed within a constant expression [4(IEEE)].
ATTEMPT #2
wire [cds_globals.NUM_BITS_VAR:0] my_wire;
==> result xmelab: *E,NOTDOT ( Hierarchical name ('cds_globals.NUM_BITS_VAR') not allowed within a constant expression [4(IEEE)].
VERSION INFO:
% virtuoso -V
@(#)$CDS: virtuoso version ICADVM20.1-64b 06/29/2021 18:30 (cpgsrv11) $
% virtuoso -W
sub-version ICADVM20.1-64b.500.19
Thank you,
Bill Huff
