  2. Mixed-Signal Design
  3. Annotate currents without adding the outputs to the ADE
  • Replies 10
  • Subscribers 67
  • Views 17779
AmarDas
AmarDas over 5 years ago
Is there any way to annotate the currents without adding the node/terminal to the ADE output section ?
I know we can add the nodes by "outputs->to be saved -> select the nodes", this will save the currents and we can annotate in the design. I have a very large schematic and if I add for every node, the output list will be so long.
Please let me know if there is a other way for this.
Amar
    ShawnLogan over 5 years ago
    Dear Amar,
    Perhaps I am not understanding your question, but if you are looking to annotate the DC current in a component from a DC operating point analysis, yes. The currents for a resistor, active device (MOS, BJT, etc.. ) are saved as part of the DC operating point analysis and can be displayed on the schematic after the analysis using the "Annotate DC operating point" feature.
    Is this what you had in mind with your question?
    The command and resultant display of some current information from a DC operating point analysis are provided in Figure 1 and 2 respectively.
    Shawn
    ShawnLogan over 5 years ago in reply to ShawnLogan
    My prior reply was posted when I logged in and was not completed - sorry! The figures are below.
    Shawn
    Figure 1
    Figure 2
  • AmarDas
    AmarDas over 5 years ago in reply to ShawnLogan
    Hi Shawn,
    Thanks for replying. Its similar to what you have explained. The "Annotate DC operating point" shows the device current(Id, I etc). I want the terminal current to be displayed in the schematic. I can do that using "Annotate DC current", but for this every terminal need to be added to the ADE output section. If I don't add the terminal it shows as "n/a" as the terminal current.
    So is there any way to see the node/terminal currents without adding them to the ADE output section.
    Amar
    ShawnLogan over 5 years ago in reply to AmarDas
    Dear Amar,
    As detailed in the Cadence On-line support RAK "Using Spectre SAVE Effectively" at URL:
    https://support.cadence.com/apex/articleattachmentportal?id=a1O0V00000910oxUAA&pageName=ArticleContent&attachId=0690V000004dkHEQAY&sq=null&caseSessionKey=null
    did you consider adding the following file as an include file in your ADE Simulation Files GUI?
    Example filename: saves.scs
    File "saves.scs" content:
    simulator lang=spectre
    save *:currents depth=1
    Include the above save.scs file from the ADE GUI under the Setup > Model Libraries section.
    This will avoid you adding the terminal currents as specific outputs as ADE outputs. Does this help?
    Shawn
  • AmarDas
    Hi Shawn,
    I am also surprised that, this didn't work for me as well. I have gone through the RAK and tried some other combinations as well.
    Amar
    Dear Amar,
    Is the added save statement providing the terminal currents for other blocks or subcircuit in your schematic?
    Shawn
  • AmarDas
    Hi Shawn,
    I just noticed it shows the terminal current for Instances(block symbols) and passive devices. But not for the active devices.
    Is there any switch that needs to be turned on ?
    Amar
    Dear Amar,
    I was afraid of that! The CDF for your model must support the notation in order for it to be displayed (i.e., annotated).] I think the following every recent troubleshooting article is the most current detailing the issue you are seeing and two workarounds. I noticed that the first workaround is what you were trying to avoid as it does produce the correct terminal current in your example...but for you is not a preferred solution based on your comments in this series of posts.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nV5EEAU&pageName=ArticleContent
    Shawn
  • AmarDas
    Hi Shawn,
    This helped a lot.
    I saw, I had wrong terminal mapping in the CDF. I ran the tran analysis to check the terminal mapping in the result browser. After updating the same in the CDF, the issue seems to be gone and I can annotate the currents.
    I really appreciate you for guiding me through out this.
    Amar
    Dear Amar,
    Wonderful - great news! Thank you, very much, for letting us know!! Good luck in your additional simulation efforts!
    Shawn
