  2. Mixed-Signal Design
  3. Extraction failure for Verilog-A due to for loop
  • Subscribers 67
  • Views 20418
UniFleSou
UniFleSou over 4 years ago
I was trying to implement a digital controlled oscillator model in Verilog-A. When I extract it, the extraction would fail (TE-4309). The code looks like this:
`include "constants.vams"
`include "disciplines.vams"
`define MATH_PI 3.14159265358979323846264338325790288419716
module DCO_VA_MODEL ( DIN, GND, CLK_OUT ) ;
input [7:0] DIN ; // little endian, DIN[0] is LSB
input GND ;
output CLK_OUT ;
electrical [7:0] DIN ;
electrical GND, CLK_OUT ;
// Parameter definition
parameter real freq_center = 1G ; // Hz
parameter real freq_range = 800M ; // Hz
parameter real vdd_supply = 1 ; // volt
parameter real din_center = 127.5 ; // LSB
// Variables for calculation
real din_digit ;
real freq_inst ;
real phi ;
real delta_phi ;
real cycle_count ;
integer i ;
analog begin
// calculate DIN in LSB
for (i=0; i<8; i=i+1) begin
din_digit = din_digit + ceil( V(DIN[i], GND) - vdd_supply/2 ) * pow(2,i) ;
end
din_digit = ( din_digit - din_center ) / pow(2,8) ;
// calculate the phi as if running at center frequency
cycle_count = freq_center * $abstime ;
phi = 2 * `MATH_PI * ( cycle_count - floor(cycle_count) ) ;
// calcualte the deviation in fet due to vin is not at the center
delta_phi = 2 * `MATH_PI * freq_range * idt( din_digit, 0 ) ;
V(CLK_OUT,GND) <+ vdd_supply/2 + vdd_supply/2 * sin(phi+delta_phi) ;
// set the simulation step
freq_inst = freq_center + freq_range * din_digit ;
$bound_step(0.04/freq_inst) ;
end
endmodule
I was able to determine that the issue has to do with the for loop since the code can be extracted without it. If I take the line in the for loop out of it and give i an integer value, the code can extract as well. I was wondering if anyone else could kindly point out my mistake?
    If you'd hovered over the red highlighted region, or looked at the View->Parser Log File you'd have seen that it said:
    Error found by spectre during AHDL compile.
    ERROR (VACOMP-1192): "din_digit = din_digit + ceil( V(DIN[i], GND)<<--? -
    vdd_supply/2 ) * pow(2,i) ;"
    "/export/home/andrewb/support/forum/mylib/DCO_VA_MODEL/veriloga/veriloga.va",
    line 27: The index that accesses bits of the analog signal vector `DIN'
    is not a constant, constant expression, genvar variable, or
    genvar-constant expression. Use only a constant, constant expression,
    genvar variable, or genvar-constant expression to access bits of an
    analog signal vector.
    You simply need to change the line:
    integer i;
    to
    genvar i;
    By the way, since you're including "constants.vams" you could have just used M_PI rather than defining your own MATH_PI (with more digits than would help, since you only have about 15-16 digits of precision in double-precision floating point numbers).
  • UniFleSou
    UniFleSou over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you for your help. I was able to fix the code with your advice.
    However, I think there is something wrong with the way I was configuring cadence virtuoso. When the veriloga extraction failed, I wasn't able to see any red highlights in my code, and when I do "View->Parser Log File", the command window just says "*WARNING* (TE-5003): No parser log file was found for '0XT_ADPLL_PROJ DCO_8B_VA_MODEL veriloga'. Use the 'Check' or 'Extract' commands to parse this cellview." This makes code writing and debugging more difficult. Still, I was able to run simulation with the veriloga model in spectre simulation. Could you advise me on how I may solve this issue? (Should I create a separate post for this?)
    In case this is needed, I was using Virtuoso ICADVM201HF and SPECTRE201HF. Here is the part of .bashrc file relating to cadence.
    # Cadence
    CADENCEVER=ICADVM201HF
    SPECTREVER=SPECTRE201HF
    export CDS="/cad/cds/$CADENCEVER"
    export PATH=$PATH:/cad/cds/$CADENCEVER/tools/bin:/cad/cds/$CADENCEVER/tools.lnx86/dfII/bin
    export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/cad/cds/$CADENCEVER/tools/lib:/cad/cds/$CADENCEVER/tools/verilog/bin
    export CDS_LIC_FILE=[REDACTED]
    export CDSHOME="/cad/cds/$CADENCEVER"
    export MMSIMHOME="/cad/cds/$SPECTREVER"
    export CDS_Netlisting_Mode=Analog
    # Spectre
    export SPECTRE_MODEL_PATH="$GF_PDK_HOME/Models/Spectre/models"
    export PATH=/cad/cds/$SPECTREVER/tools.lnx86/spectre/bin:$PATH
    export CDS_AUTO_64BIT=ALL
    export SPECTRE_DEFAULTS=-E
    export CDS_LOAD_ENV=CSF CWDElseHome
    Thank you and happy new year!
    Andrew Beckett over 4 years ago in reply to UniFleSou
    There are a couple of odd things in your settings above, but I don't think any of them would cause the problem (I tried setting up my environment in a similar fashion but couldn't reproduce it). The specific points I had about the environment are:
    1. You don't need to set LD_LIBRARY_PATH and certainly not include tools/verilog/bin in that path
    2. Usually you'd add either /cad/cds/$SPECTREVER/bin in the path or maybe (if you need to support very old versions of MMSIM) /cad/cds/$SPECTREVER/tools.lnx86/bin . I wouldn't include tools/spectre/bin (the world won't end, but it's not a recommendation)
    3. It's slightly unusual to have -E specified as a SPECTRE_DEFAULT
    I wonder whether it might be an issue with the specific versions used (ICADMV201HF and SPECTRE201HF aren't very specific). What does "virtuoso -W" and "spectre -W" report in the terminal window?
  • UniFleSou
    I feel really stupid for saying this, but I forgot to give myself write permission to the ".cadence" folder in the work directory when I copied it from the PDK files. Giving myself full read/write permission to the ".cadence" folder and everything in it solved the issue I mentioned.
    Thank you again for your kind help!
