  2. Mixed-Signal Design
  3. verilog AMS sine wave generator
  • Subscribers 67
  • Views 17972
praseetha
praseetha over 4 years ago
 Re: Verilog AMS sine generator
Reply #2 - Today at 1:03am
Hi ,
 I have created a wrapper around my  .vams netlist of an anlog circuit. I want to drive a signal as an input from the digital domain to my analog netlist hence I created a wrapper.
The input to the wrapper is a frequency ,phase and amplitude but I want to drive a sine wave as input to my analog netlist, hence I am creating this in my wrapper and trying to feed that as input to my vams netlist as it needs a signal as an input.
This is the part of the code which I need help with:
electrical      bbmux_lp_n_ai;
 electrical      bbmux_lp_p_ai;
 electrical      lp_n_ai;
 electrical      lp_p_ai;
 real       offset = 2.5;
 assign  bbmux_lp_n_ai = offset + (bbmux_lp_n_ai_amplitude * $cos(2*3.14159265358979323846*bbmux_lp_n_ai_frequency*$abstime));
 assign  bbmux_lp_p_ai = offset + (bbmux_lp_p_ai_amplitude * $cos(2*3.14159265358979323846*bbmux_lp_p_ai_frequency*$abstime));
 assign  lp_n_ai = offset + (lp_n_ai_amplitude * $cos(2*3.14159265358979323846*lp_n_ai_frequency*$abstime));
 assign  lp_p_ai = offset + (lp_p_ai_amplitude * $cos(2*3.14159265358979323846*lp_p_ai_frequency*$abstime));
   // Instantiate the analog netlist
 rxbb_lp rxbb_lp_inst(
   .bbmux_lp_n_ai(bbmux_lp_n_ai) ,
   .bbmux_lp_p_ai(bbmux_lp_p_ai) ,
   .lp_n_ai(lp_n_ai) ,
   .lp_p_ai(lp_p_ai)
I also tried creating a seprate function as shown in the guide:
electrical g, gnd;
wire bbmux_lp_n_ai;
wire bbmux_lp_p_ai;
wire lp_n_ai;
wire lp_p_ai;
vsine #(.dc(0), .ampl(1.3), .freq() bbmux_lp_n_ai (g, gnd);
vsine #(.dc(0), .ampl(bbmux_lp_p_ai_amplitude), .freq(bbmux_lp_p_ai_frequency)) bbmux_lp_p_ai (g, gnd);
vsine #(.dc(0), .ampl(lp_n_ai_amplitude), .freq(lp_n_ai_frequency)) lp_n_ai (g, gnd);
vsine #(.dc(0), .ampl(lp_p_ai_amplitude), .freq(lp_p_ai_frequency)) lp_p_ai (g, gnd);
   .lp_n_ai(lp_n_ai) ,
   .lp_p_ai(lp_p_ai)
endmodule
module vsine(ampl,freq,phase,out);
input ampl;
input freq;
input phase;
output out;
voltage out;
real freq, ampl,phase;
parameter real offset=0.0;
analog begin
v(out) <+ ampl*sin(2.0*‘M_PI*freq*$abstime) + offset;
$bound_step(0.05/freq);
end
endmodule
    As Ken pointed out in your post on The Designer's Guide forums (you didn't really disguise the fact that you'd posted there given the pasted Quote/Modify icons!), you haven't really asked a question. Since this is already an active discussion on the Designer's Guide, I won't answer it here too. Mainly because you've not actually asked a question and just pasted some code and said what you're doing, but also to avoid duplication, even though it's a different forum.
  • praseetha
    praseetha over 4 years ago in reply to Andrew Beckett
    I am trying to create a sine wave in my wrapper, to feed that as an input to my .vams netlist. I am not able to achieve that with this code script and I i am looking for a better way to achieve it as it is is not working.
    Firstly, is this possile by the wrapper?
    second, is my method correct? or can I have some suggestions.
    I am sorry that I have duplicated it as I was just looking for an open discussion and did not know that it is a problem.
    Thank you
    Andrew Beckett over 4 years ago in reply to praseetha
    I see Ken has given you lots of answers in the Designer's Guide post so I won't repeat that work here.
  • praseetha
    Yes, he has, Thank you.
