  2. Mixed-Signal Design
  3. How to include a verilog file/functional view in HED?
  • Replies 8
  • Subscribers 68
  • Views 9654
Johanny Saenz
Johanny Saenz over 4 years ago
Hi all
I'm doing an AMS simulation and I'm instantiating a block whose definition is included in a Verilog file and also a functional view. In the HED, I can't define a hierarchy beneath a functional view.
How can include that file definition in an easy way?
Thanks all.
    Andrew Beckett over 4 years ago in reply to Johanny Saenz +1
    This unfortunately is a known limitation. The main issue is that generate blocks are parameterised connectivity and that cannot really be represented in parent-child database that HED uses. The workaround…
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to Johanny Saenz +1
    ... as explained at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006DdhMUAS
  • Johanny Saenz
    Hi all
    How can include that file definition?
    Please do not post the same question in multiple forums (see the forum guidelines). It won't necessarily get answered any quicker - usually the opposite because it creates more work...
    This time I've joined the two posts rather than deleting them both.
    It's not clear what you mean. What does it mean by "I'm instantiating a block whose definition is included in a Verilog file and also a functional view"? Where are you instantiating it? You can certainly have hierarchy beneath a functional view and you should be able to view switch using HED.
    Perhaps contacting customer support would be best?
  • Johanny Saenz
    Johanny Saenz over 4 years ago in reply to Andrew Beckett
    For example, I have the following verilog created as a functional view in Virtuoso:
    module SRAM_BLOCK
    #(parameter WIDTH_INPUT=64, WIDTH_OUTPUT=4,WIDTH_DATA=8)
    input clk_fifo_i,
    input rst_mst_i,
    input eval_i,
    input [7:0] cmp_i,
    input [WIDTH_DATA-1:0] counter_i,
    input load_fifo_i,
    output [WIDTH_OUTPUT-1:0] SO
    DESER_FIFO64 I_DESER ( clk_fifo_i, DATA[WIDTH_INPUT-1:0], rst_mst_i, load_fifo_i, SO[3:0]);
    endmodule
    In my HED I will have the stopped view configured to functional, but spectre is reporting me the following error:
    SRAM_BLOCK:module' was set to be stop view in Cadence Hierarchy Editor(HED) but this instance has hierarchy beneath it. Review and update its settings in HED appropriately
    I have to add somehow the DESER_FIFO64 definition. I have tried `include statement without success.
    How can I do it from HED?
    Why are you setting the functional view to be a stop view? It's not a stop view! You want the hierarchy expanded beneath it, so it makes no sense to make it a stopping view.
  • Frank Wiedmann
    By the way, the function of the Stop View List is explained at https://support.cadence.com/apex/techpubDocViewerPage?path=assembler/assemblerIC6.1.8/asmNetlisting.html#pgfId-1024871
  • Johanny Saenz
    Johanny Saenz over 4 years ago in reply to Frank Wiedmann
    Hi Andrew and Frank.
    I have found the issued Verilog portion :
    genvar i;
    generate
    for (i=0; i<7; i=i+1) begin
    SRAM I_SRAM( rst_mst_i, eval, counter_i[7:0], cmp_i[i], DATA[8*(i+1)-1:8*i]);
    end
    endgenerate
    Using generate statement, HED is unable to descend into SRAM hierarchy.
    How can I work around it?
    This unfortunately is a known limitation. The main issue is that generate blocks are parameterised connectivity and that cannot really be represented in parent-child database that HED uses. The workaround is to add a reference to the external file with the definition of the SRAM in the Verilog-AMS options.
  • Frank Wiedmann
