  2. Mixed-Signal Design
  3. *ERROR* (AMS-1247): AMS UNL netlisting has failed --> With...
  • Subscribers 67
  • Views 8349
*ERROR* (AMS-1247): AMS UNL netlisting has failed --> With XCELIUM21.09
RFStuff
RFStuff over 4 years ago
Dear All,
I installed XCELIUM21.09 and SPECTRE 21.1 -ISR4.
I was earlier able to run my AMS testbench (this has only Verilog-Modules) successfully with INCISIVE-15.2.
But, now with the lattest XCELIUM installation, I see the following error.
I checked the assembler.log file and that suggests the error cause as below:-
sh: /P/cadence/installs/SPECTRE211/tools/spectre/bin/cds_plat: No such file or directory
Error : Failed to find out assembler libraries in spectre installation.
Please specify IUS installation path to spectre and try again.
dna_assembler failed. (1)
Could anybody please tell why this error is cropping up ? and what is IUS path being asked here ?  Earlier I didn't have to give this path in my .cshrc file.
How can I fix this issue ?
Kind Regards,
    No idea (I didn't find anything specifically on this, and would need a fair bit of thought to try to figure out all the possible reasons for why this might fail, whereas seeing your setup would make that much easier). Please contact customer support - my guess is that you have something wrong with your UNIX paths (or have some wrappers in the way which are breaking things). In current versions you need both Spectre and XCELIUM in your path (the AMS Flex option takes care of this - we now use the analog solver from the spectre installation, whereas historically it was shipped along with INCISIVE). The same is true for the UNL netlisting - parts come from XCELIUM and parts from Spectre.
  • RFStuff
    RFStuff over 4 years ago in reply to Andrew Beckett
    Thanks Andrew.
    We don't have support for Xcelium product.  So we are at our own and your help  (with tight time constraints) is higly appreciated.
    I understand about UNIX paths. But what is "some wrappers coming in the ways"  means here?
    What are "assembler libraries in spectre installation" that AMS is looking for here ? I think I have given both the paths of XCELIUM and SPECTRE in the UNIX path.
    1:-
    We have installed :-  spectre location :- /P/cadence/installs/SPECTRE201/  --> MMSIM
                                     Xcelium location :- /P/cadence/installs/XCELIUM2109/ -->AMSHOME
                                     IC618 location :-  /P/cadence/installs/IC618/   --> CDS_INST_DIR
    2:-
    Accordingly,
    corresponding enviornemnt variables and the paths given in the SET-UP cadence.cshrc file are as below:-
    #!/bin/csh
    set filec
    setenv CDS_INST_DIR /P/cadence/installs/IC618
    setenv MMSIM /P/cadence/installs/SPECTRE201
    setenv AMSHOME /P/cadence/installs/XCELIUM1903
    setenv CDS_Netlisting_Mode "Analog"
    set icpath=($CDS_INST_DIR/tools/bin $CDS_INST_DIR/tools/dfII/bin $CDS_INST_DIR/tools/dracula/bin)
    set path=(. $icpath $path)
    setenv LD_LIBRARY_PATH
    set LD_LIBRARY_PATH=($CDS_INST_DIR/tools/lib $LD_LIBRARY_PATH)
    setenv SPECTRE_FEATURE_FILE $MMSIM/tools/spectre/etc/files/spectre.dat
    set path=($MMSIM/tools/bin $AMSHOME/tools/bin $path)
    set path=($MMSIM/tools/spectre/bin $path)
    #---- End of Cadence Setup --------------------------------------
    alias ic 'virtuoso &'
    alias cde 'Xsession &'
    3:-
    The versions we are using are:-
    sub-version IC6.1.8-64b.500.23
    sub-version 20.1.0.434.isr14
    TOOL: xrun(64) 21.09-s006
    Kind Regards,
  • RFStuff
    RFStuff over 4 years ago in reply to RFStuff
    4:-
    I run AMS simulation (the testbench doesn't have any analog moduels it has only verilog blocks) as below:-
    Andrew Beckett over 4 years ago in reply to RFStuff
    I'm sorry, but this makes no sense. You said in your previous post that you'd purchased XCELIUM - so you should have support. Please contact whoever you purchased it from.
    Quick response though - and as I said, debugging this here is really not practical (and I don't have time to do so on the weekend), you don't appear to have any wrapper scripts around spectre, xrun etc and are running directly from the path.
    I see you have MMSIM/tools/bin and MMSIM/tools/spectre/bin in your path - that's not really necessary. I'd just put MMSIM/bin in the path and nothing else. Also, do not set SPECTRE_FEATURE_FILE - this is only necessary if you have wrappers around the executables which prevents the automated mechanism from finding the feature file. It's only likely to cause you trouble if you set it yourself and it ends up at the wrong path for whatever reason.
  • RFStuff
    Dear Andrew,
    Thanks a lot. I removed SPECTRE_FEATURE_FILE  from my setup file and now it started to run properly.
    My impression of no support for Xcelium product comes out of the fact that I could not find Xcelium in my product drop-down list while submitting the case in Online Support website. Anyway, we will contact Cadence University co-ordinator regarding this.
    Again, thanks a lot for your help.
    Kind Regards,
