  2. Mixed-Signal Design
  3. DC sweep and transient at same time
  • Subscribers 67
  • Views 15953
atulkumar245
atulkumar245 over 4 years ago
simulator lang=spectre
include "bsim3v3.lib"
ahdl_include "VO2.va"
ahdl_include "capacitor.va"
Vc (v 0) vsource type=pulse val0=0 val1=6 delay=0 rise=0.05n fall=0.05n width=180us period=220us
//Vc(v 0) vsource dc=0.6
Vg(vg 0) vsource dc=6
Hb (v x 350 1 300) VO2_device
C1 (x 0) cap1 c=40pF
m1 (x vd 0 0) nmos l=0.5u w=2u
doTran tran stop=180us
simulator lang=spice
.measure tran t1 when x=3 cross=2
.measure tran t2 when x=3 cross=4
.measure tran freq param '1/(t2-t1)'
//analysisDCswp1 sweep param=dc dev=Vg start=1 stop=20 step=1
This is the code for a circuit that is oscillating for a given vd value. So I have used doTran to capture oscillation. And used the  .measure  to calculate frequency. But this can be done for only 1 vg value. But I need to plot frequency vs Vg plot . How I can do that??
Atul
    Atul, It's just putting the sweep in the right place: analysisDCswp1 sweep param=dc dev=Vg start=1 stop=20 step=1 { doTran tran stop=180us } saveOptions options save=allpub simulator lang=spice…
    Atul,
    .measure tran t1 when V(x)=3 cross=2
    .measure tran t2 when V(x)=3 cross=4
  • atulkumar245
    atulkumar245 over 4 years ago in reply to Andrew Beckett
    Thanks a lot, Sir. It worked
    I used this way to calculate frequency because oscillation was crossing 3 every time.( First calculating t1 , t2 and then frequency)
    Is there any better alternative??
    Andrew Beckett over 4 years ago in reply to atulkumar245
    Seems reasonable - it probably depends on what your expected threshold voltage would be in whatever the oscillator is driving.
  • atulkumar245
    Thanks, sir for helping me out. When I vary Vg, some of the Vg frequency is coming to NaN. The reason for that can be that for different Vg, crossing value changes and so I have to change accordingly. How will I implement this in Verilog A? Please help me out.
    I don't really see what Verilog-A has to do with altering a .measure statement. I'm not sure what you're varying (maybe it's different from the original example above) or how you determine the threshold - the threshold in the .measure statements could be another node voltage in the design, so if you can arrange to have a voltage source in the circuit that also changes you could use that.
