  2. Mixed-Signal Design
  3. Accurate sampling (or scheduling an accurante time event...
  • Subscribers 67
  • Views 15124
Accurate sampling (or scheduling an accurante time event) in SPECTRE
RFStuff
RFStuff over 4 years ago
Dear All,
I like to sample a node voltage in my testbench at accurate time instants by using a clock of period of 1ns.
One way of doing this is using a verilog-A module with cross( ) function. But cross() has accuracy limits set by expr_tol and time_tol from actual crossing.
So, transient simulation result is equivalent to having a jittery clock that samples the node-voltage (i.e. I am Not getting the node voltage values at the actual crossing ( the instants at multimples of 1 ns. 1ns,2ns.....etc).
How can I reduce the deviation ? What minimum time_tol value I can set ?  Can I set it to 1 fs ?
    ShawnLogan over 4 years ago
    Dear RFStuff,
    I would suggest using a conventional transient simulation with sufficient accuracy settings. For example, if you are using spectre +aps, you might choose an errpreset of "conservative" to minimize simulator error. You may also consider setting a maximum tilmestep (parameter maxstep set to some value) as that will force the simulator to sample your signal at least every maxstep seconds.
    You might consider the following:
    1. Use the Calculator cross() function to locate the times at which your signal of interest crosses the voltage threshold you are showing in your figure. You can create a waveform of the threshold crossings and either plot them as a function of time or cycle number. The error can be quantified by choosing a threshold of value "threshold + epsilon" and, perhaps, "threshold - epsilon" and determine the set of time values that correspond to these two thresholds. Take the difference between the crossings at "threshold" and those at thresholds of "threshold + epsilon" and "threshold - epsilon". This indicates how much temporal error might result from an interpolation of +/-epsilon from the actual crossing time.
    2. If your signal to be sampled is synchronous with your sampling clock of 1 GHz, set the strobe time parameter for your transient simulation to 1 ns or some integer submultiple of 1 ns. Perform your simulation as before with an errpreset of "conservative" and utilize the Calculator cross() function. If your signal and sample clock are synchronous, their may be an offset in the reported sample times, but the variation in the sample times (i.e., wander or jitter" should be minimized.
    This may not help at all if you are only interested in using your veriloga module, but thought I would pass my thoughts along.
    Shawn
  • RFStuff
    RFStuff over 4 years ago in reply to ShawnLogan
    Thanks ShwanLogan.
    Can I set minimum time_tol value to 1 fs here to minimize the deviation here ?
    ShawnLogan over 4 years ago in reply to RFStuff
    Dear RFStuff,
    Yes, but I don't think that will help your basic issue. The time_tol only places timepoints at the corners of your waveform transition - and NOT about the threshold crossing. Hence, you still need may need to interpolate the signal to find the time of the threshold crossing. The veriloga manual states:
    "This option requires the simulator to place time points no more than the value of time_tol away from the two corners of the transition."
    I hope I understood your question correctly...
    Shawn
  • RFStuff
    Dear ShwanLogan,
    If you see the page 129 as below , it clearly says that by setting time_tol you can come closer to the desired actual crossing and minimize the deviation.
    Andrew Beckett over 4 years ago in reply to RFStuff
    You're probably also being constrained by your long stop time, similar to what I say here.
    In general the controls for cross should be sufficient and give good accuracy in most situations. If you need to further improve the determination of the crossing time you can use last_crossing() which interpolates to improve the time the crossing occurred at. That's mainly for improved determination of the time though rather than the sample value.
