  2. Mixed-Signal Design
  3. Cadence virtuoso Vs. ADS
  • Subscribers 67
  • Views 15315
Hammam
Hammam over 4 years ago
Hello everyone,
I am using ADS for simulating H-bridge and I have an antenna circuit using NRZ signalling. I looked into the ADS website which shows that it is compatible with Cadence virtuoso and I wonder what can Cadence do over the ADS simulator? I am working on mixed signals.
All the best
    ShawnLogan over 4 years ago +1
    Dear Hammam, Hammam said: I looked into the ADS website which shows that it is compatible with Cadence virtuoso There is a Rapid Adoption Kit document and example that details the methodology to…
    Andrew Beckett over 4 years ago in reply to ShawnLogan +1
    In addition to Shawn's feedback, if you're already a Cadence customer, then you should contact your account team. If not, contact your local office or if unsure you could make a sales enquiry via Send…
    Dear Hammam,
    There is a Rapid Adoption Kit document and example that details the methodology to import ADS based models into Virtuoso. The document is at the On-line Support URL:
    https://support.cadence.com/sfc/servlet.shepherd/version/download/0680V000003dZqfQAE
    I can't add anything regarding your question as I do not have recent experience with the ADS simulation methodologies. I do, however, believe the scope of Virtuoso tools far exceeds the more RF/Microwave focused ADS.
    Shawn
    In addition to Shawn's feedback, if you're already a Cadence customer, then you should contact your account team. If not, contact your local office or if unsure you could make a sales enquiry via  Send Us A Message on the main Cadence web site. This is the kind of question that really needs a more detailed discussion on your needs to determine which tools would be the best fit and what the advantages of those might be.
