  2. Mixed-Signal Design
  3. The SNR of real signals are degrading in system Verilog...
  • Subscribers 68
  • Views 12694
The SNR of real signals are degrading in system Verilog model compare to analog signals
bikram1994
bikram1994 over 4 years ago
Hi
The SNR of real signals are degrading in system Verilog model compare to analog signals.
Am I missing anything in the setup or in the code?
Can I improve the SNR of real signal inside system Verilog model?
Please help me.
Here I have put the test bench and all .
Test Bench:
config:
Vinm:
vinp:
Code: SystemVerilog
//systemVerilog HDL for "ProjA1_AMS_tb", "INP_Check_sv" "systemVerilog"
`timescale 1ns / 1ps
module INP_Check_sv
input logic clk_5p4Ghz, //5.4Ghz clock
input real adc_in1 , // Signal time samples
input real adc_in2 , // Signal time samples
output bit [1:0] adc_out
real inp;
assign inp=(adc_in1-adc_in2)/2;
endmodule
Spectrum of vinp:
SNR=226.74dB
Spectrum of adc_in2:
SNR=52.7dB
    The issue is that you're seeing the behaviour of the electrical to real connect module that is being inserted automatically between the voltage sources and your SystemVerilog model (I didn't test this, but I'm sure this is going to be it). See the discussion on vdelta in this post.
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    I just went through checking this as you'd posted that it wasn't working, and having validated it, I see that you've deleted your post about it not working (so I assume you found the problem).
    Anyway, for completeness, here's the results I get (the step size in the transient waveform is tiny now - whereas it was very busy with the default vdelta):
  • bikram1994
    bikram1994 over 4 years ago in reply to Andrew Beckett
    Hi Andrew!
    Thank you very much.
    Now it is working. I did a mistake in my setup.
