  2. Mixed-Signal Design
  3. how to create a random seed in verilogams with $random
  • Subscribers 67
  • Views 16722
Pedro P
Pedro P over 4 years ago
I am struggling to create a random seed in verilogams, I know how to create a random see in systemverilog, thats easy, but what about in verilog ams ?
I have created the following verilogams code, where the parameter seed=0 , and my expectation is that every-time i run this code i would get an initial seedx using $random , that should be different every-time based on the PID.
I see this in solution in multiple cadence documents, but the reality is whenever i run it I always get the same seedx , meaning that $random produces the same number at time 0 , in the initial block.
Can someone help me whit this ?
im using :
cadence 06.18.240
xcelium 21.09.007
spectre 21.10.303
module ams (en);
input en;
// seed of 0 should give a random seed based on the PID
parameter integer seed = 0;
integer seedx;
initial begin
   seedx = (seed == 0) ? $random : seed;
end
endmodule
    I'm wondering why you think it should be based on the process id? The Verilog-AMS Language Reference manual (from Accelera) says:
    The random_seed argument may take one of several forms. It may be omitted, in which case the simulator picks a seed. If the call to $random is within the analog context, the random_seed may be an analog integer variable. If the call to $random is within the digital context it may be a reg, integer, or time variable. If the random_seed argument is specified it is an inout argument; that is, a value is passed to the function and a different value is returned. The variable should be initialized by the user prior to calling $random and only updated by the system function. The function returns a new 32-bit random number eachtime it is called.
    The system function $random shall always return the same stream of values given the same initial random_seed. This facilitates debugging by making the operation of the system repeatable.
    It doesn't say anywhere about the simulator-generated seed being different based on the process id (which would go against the last sentence).
  • Pedro P
    Pedro P over 4 years ago in reply to Andrew Beckett
    Hi Andrew I have found the LRM and for me it wasn't not 100% clear about the "The function returns a new 32-bit random number each time it is called" and so I thought was related to the PID.
    I noticed that in my example, where i use the $random in a digital context without (initialising the seed / passing a seed to the function) , that in my example I always get the same seedx value over and over again.
    in systemverilog I can use -svseed random , but in the case of verilogams , how can i get a way of generating a new random seed whenever I lunch a new simulation ? is there a way I could do that ?
    Thank you, Pedro.
    Andrew Beckett over 4 years ago in reply to Pedro P
    Of course, the whole point of $random is that each time it is called (within a simulation) it returns a new 32-bit random number. It doesn't say anything that the sequence itself will be different from one invocation of the simulator to another.
    There's not (as far as I can find) any option to initialize the default seed from the command line for Verilog-AMS. Of course, you could use:
    $random(`AMSSEED)
    and then on the command line use -define AMSSEED=2 or similar.
