  2. Mixed-Signal Design
  3. How to see all the running simulation?
  • Subscribers 67
  • Views 12053
bikram1994
bikram1994 over 4 years ago
I want to see all the jobs running. bjobs command used to show that information. But bjobs command is not working right now. Is there any alternative command like bjobs?
Thank you
    ShawnLogan over 4 years ago
    Dear bikram1994,
    Is the command "bqueues" functioning? This will provide a list of all LSF queues and the number of jobs running, pending, or suspended for each.
    Shawn
  • bikram1994
    bikram1994 over 4 years ago in reply to ShawnLogan
    Hi Shawn,
    The 'bqueues' command is not working also.
    Thanks & Regards,
    Bikram
    Andrew Beckett over 4 years ago in reply to bikram1994
    Bikram,
    I'm assuming you're even using IBM LSF to submit your jobs? bjobs/bqueues are not Cadence commands - if something is not working with them, you'll need to speak to your IT or whoever is responsible for your LSF cluster. It's a bit of an odd question to be asking here - and if you are not using LSF to submit your simulation jobs, you'll need to explain how you're submitting them...
