  2. Mixed-Signal Design
  3. Xcelium version for cosim
  • Subscribers 67
  • Views 11231
paulinho
paulinho over 4 years ago
I'm  using Virtuoso: IC6.1.8-64b.500.14 and Xcelium: 21.03 May 2021.
Can i do co simulations using these 2 versions ?
If not which is the latest version of Xcelium which is compatible with the above mentioned version of Virtuoso ?
    There were some version incompatibilities due to compiler changes in various IC/XCELIUM release combinations. This is covered in this article Cannot start Virtuoso if using Xcelium 21.03 or 21.09 which shows which versions you'd need to use in order to do AMS simulation with Virtuoso.
