  2. Mixed-Signal Design
  3. VerilogA: analysis function will not take a string vari...
  • Subscribers 67
  • Views 12611
VerilogA: analysis function will not take a string variable
NewScreenName
NewScreenName over 4 years ago
I am trying to create my own analysis dependent switch.
Let's say I want it to be a closed switch during a certain analysis that I decide as a parameter when I instantiate the switch, and open otherwise, thus I wrote the following below. However I get an error "incorrect argument type for 'analysis'. specify one or more constant string arguments".
Now I am quite unsure how to solve this, ana is indeed defined to be a string, and if I wrote analysis("dc") instead of analysis(ana), then it would work properly.
`include "constants.vams"
`include "disciplines.vams"
module analysis_switch(in, ou);
inout in, ou;
electrical in, ou;
parameter string ana = "dc";
analog begin
if(analysis(ana))
V(ou,in)<+0;
else
I(ou,in)<+0;
end
endmodule
Thank you
    There's the built-in component switch in spectre which does this already. Can you use that instead? If using in Virtuoso, there is the sp[1234]tswitch components in analogLib which netlist to the spectre switch component.
    The approach above won't work because the analysis function expects a literal constant string (this is clear from the Verilog-AMS standard LRM too).
  • NewScreenName
    NewScreenName over 4 years ago in reply to Andrew Beckett
    Thank you for your reply.
    The reason I am not using the component provided in analogLib is because it allows you to choose only among DC, AC, tran, IC. Now suppose in a testbench I want the switch to be open only for sp analysis and closed for any other analysis, then, correct me if I am wrong, the sp[1234]tswitch will not do the job, right?
    Regarding the literal constant string: it is not clear to me when I write string ana ="something"; now isn't ana a string? And so, what is the difference between this string and such expected literal constant string? (even when it is not a parameter it won't work).
    I've had a look at the verilog AMS LRM, and from there paragraph 3.3 it looks to me like "something" being a literal string, when assigned to a variable var="something" then var becomes a string, which is something different than a literal constant string. So what could be the workaround to have a switch with a parameter where I choose the target analysis? (otherwise I should create a cell for each different combination of analyses that I want it to be selective to).
    Andrew Beckett over 4 years ago in reply to NewScreenName
    I believe that "ac" will work for sp analysis too on the switch component (I didn't check to be sure though). It would be very strange to only want a setting for a model in a specific analysis (i.e. "sp" and not "ac"), but maybe you want this for some reason.
    Anyway, the issue is not that. you can't have string parameters - of course you can. The issue is that the analysis function only supports literal strings. From A.8.2 Function Calls:
    analysis_function_call ::= analysis ( " analysis_identifier " { , " analysis_identifier " } )
    Notice that the analysis_identifier are in quotes. It doesn't support parameters or variables with the analysis. This is probably because it needs to be known quite earlier for compilation/optimisation purposes. The message you are getting is indicating that it needs a constant string expression as the argument to analysis. Passing a parameter would need this to be resolved differently on each instance of the model, for example.
  • NewScreenName
    Alright, so it I understand there is not really a workaround for this, but creating one cell for each specific set of analyses I want my switch to be selective to.
    Thank you for your answers
