  2. Mixed-Signal Design
  3. Array of design variables for an array of Instances
  • Subscribers 67
  • Views 11594
VincentCheung
VincentCheung over 4 years ago
Basically same question as: https://community.cadence.com/cadence_technology_forums/f/mixed-signal-design/47008/create-an-array-of-variables-using-an-array-of-vdc-instances
Given: <0:3> instances of vpulse instances
Desire:
  • Assign desvar<0> design variable for <0> vpulse instance
  • Assign desvar<1> design variable for <1> vpulse instance
  • Assign desvar<2> design variable for <2> vpulse instance
  • Assign desvar<3> design variable for <3> vpulse instance
  • Simulate using spectre simulator in ADE Assembler
Does the bussetp.il method that Andrew wrote up work for this? support.cadence.com/.../ArticleAttachmentPortal
Can someone please confirm? Thanks!
Best regards, Vincent
    You can't have different design variables on each iteration of an iterated instance. All you can do is create separate individual instances or create a pcell (similar to bussetp) which does this for you. You wouldn't be able to use bussetp to do this, but you could use something inspired by it, I guess.
  • VincentCheung
    VincentCheung over 4 years ago in reply to Andrew Beckett
    Thanks Andrew! Please close this thread.
