  2. Mixed-Signal Design
  3. How to define current in verilogams-wreal model ?
  • Subscribers 67
  • Views 13196
bikram1994
bikram1994 over 4 years ago
Hi All,
In verilog-a model we can define a node current like
I(pin) <+ 2u;
Is there any way to define the current in verilogams-wreal model?
Thanks in advance.
Bikram Biswas
    If it's a wreal model then the output is just a variable - you assign it with the normal assignment operator (i.e. "=") rather than a contribution statement. Without seeing the details of your model, it's hard to be more specific.
  • bikram1994
    bikram1994 over 4 years ago in reply to Andrew Beckett
    Thank you for the response.
    Let me explain the problem with an example.
    Verilog-A code of this block:
    `include "constants.vams"
    `include "disciplines.vams"
    module bias(en_1,en_2,VDD,VSS,V_out,I_out);
    input en_1;
    electrical en_1;
    input en_2;
    electrical en_2;
    input VDD;
    electrical VDD;
    input VSS;
    electrical VSS;
    output V_out;
    electrical V_out;
    output I_out;
    electrical I_out;
    analog begin
    if(V(en_1)>0.45) V(V_out) <+ 800m;
    else V(V_out) <+ 0;
    if(V(en_2)>0.45) I(I_out) <+ 2u;
    else I(I_out) <+ 0;
    end
    ensmodule
    verilogams_wreal model:
    `timescale 1ns/1ps
    input en_1;
    wreal en_1;
    input en_2;
    wreal en_2;
    input VDD;
    wreal VDD;
    input VSS;
    wreal VSS;
    output V_out;
    wreal V_out;
    output I_out;
    wreal I_out;
    real ts;
    initial begin
    ts = (0.04 / 13G) * 1e9;
    end
    always #ts begin
    if(en_1>0.45) V_out) = 800m;
    else V_out =0;
    if(en_2>0.45) I_out) = 2u;
    else I_out = 0;
    end
    ensmodule
    Here in verilogams-wreal model, can't we define voltage and current explicitly?
    Andrew Beckett over 4 years ago in reply to bikram1994
    I didn't try your code, but there are some typos - you have some extra close parentheses:
    else V_out =0;
    else I_out = 0;
    I think if you remove those, it should work.
