  2. Mixed-Signal Design
  3. CDF callback discrepancies between design variables and...
  • Subscribers 68
  • Views 10903
CDF callback discrepancies between design variables and hard-coded parameter values
VincentCheung
VincentCheung over 4 years ago
please see attached images (pic 1.png, pic 2.png, pic 3.png, pic 4.png):
  • pic 1.png shows the simple testbench setup.
    • I am comparing IDS_N1 with IDS_N2.
    • N1 has its width parameter assigned with a design variable, Wn.
    • N2 has its width parameter assigned with a hardcoded value that is equal to whatever Wn is set to.
    • I run a simple transient simulation (or DC, doesn't matter) and do the comparison stated above.
      • Example: set Wn=120nm, then hardcode N2 to have width = 120nm. Compare IDS_N1 with IDS_N2.
      • Ideally, IDS_N1 = IDS_N2.
  • pic 2.png shows the results from the testbench above.
    • In the table: IDS_N1 = Ids_sat_n in the "Equations (Design Variable)"
    • In the table: IDS_N2 = Ids_sat_n in the "PCELL (Hard-coded)"
    • For Wn <= 145nm: there are significant discrepancies between IDS_N1 & IDS_N2.
      • In the table: as, ad, ps, pd, nrd, nrs are CDF parameters for the NFET device - there are significant discrepancies between design variable vs hard-coded.
    • For Wn >= 150nm: there are 0 discrepancies between IDS_N1 & IDS_N2.
      • In the table: as, ad, ps, pd, nrd, nrs are CDF parameters for the NFET device - there are no discrepancies between design variable vs hard-coded.
  • pic 3.png shows the edit cell properties for the NFET with W=Wn.
    • You can see that the 6 CDF parameters boxed in red all have equations that are dependent on Wn (you don't actually see Wn in the screenshot because the textbox cuts it off).
  • pic 4.png shows the CDF editor for the NFET cell:
    • You can see that the 6 CDF parameters boxed in red all have a CDF SKILL callback function: tsmcN65lo_nch_macCB().
    • I believe this CDF SKILL callback function is the root cause and main culprit of this issue.
Question: Does anyone have any how to debug and resolve this issue? My best guess is that the issue lies within the SKILL code for tsmcN65lo_nch_macCB() but I don't know where to locate this code?
Pic 1
Pic 2
Pic 3
Pic 4
Thanks!
Best regards, Vincent
  • mschw
    mschw over 4 years ago
    Dear Vincent,
    you could try pretty printing the SKILL code by executing pp(tsmcN65lo_nch_macCB) in the CIW.
    If that works you can investigate the code and look for the root cause.
    I suppose that will not work, because foundries typically encrypt their CDF callbacks.
    You could also try to compare the netlists (Design Variable vs. Hard-coded) and look for discrepancies.
    Anyhow, I suggest that you contact customer support of TSMC.
    Kind regards
    Matthias
  • VincentCheung
    VincentCheung over 4 years ago in reply to mschw
    Thanks Matthias! The pretty print definitely confirmed that tsmcN65lo_nch_macCB is definitely encrypted.
    I will take a look at the netlist and do a comparison. Thanks again!
