  2. Mixed-Signal Design
  3. vsource will not accept expressions in its parameters
  • Subscribers 67
  • Views 10439
NewScreenName
NewScreenName over 4 years ago
Hi all,
I am trying to generate a signal as a sum of sinusoids whose frequencies are linear combinations of four parameters (f1, f2, f3, f4). In the first picture you can see how I set it up.
However at the time of running the simulation, the error shown in the second picture appears. So it looks to me like the issue is that vsource will not accept expressions as frequencies and amplitudes? Is there any way to have it working this way without me having to manually calculate and insert the new set of frequencies everytime I change one of the f1,f2,f3,f4 parameters?
Thank you very much
Best regards
    This is because of a quirk with the Spectre language - expressions inside vectors have to be surrounded by parentheses. In the Virtuoso version I'm using (IC6.1.8 ISR27) the frequencies do get netlisted with parentheses around the expressions, but the amplitudes don't - so change to: (0.5*Ain/Ntones) . Check the netlist - if the frequency expressions are not in the version you're using (I wonder if they are not, because the errors you get are slightly different), try adding parentheses around each of the frequency expressions.
    I think we need to fix the netlisting of this component to put parentheses around the amplitude expressions automatically.
  • NewScreenName
    NewScreenName over 4 years ago in reply to Andrew Beckett
    Perfect, now it's working correctly, thank you!
