  2. Mixed-Signal Design
  3. Is that possible to write an external function and call...
  • Subscribers 66
  • Views 10609
Is that possible to write an external function and call it in Virtuoso Verilog-A through VPI
HiddenOnee
HiddenOnee over 4 years ago
Hi, I want to write an own function and link it to the Verilog-A, is there a way to do so in Cadence Virtuoso
    From the Verilog-A documentation: Calling functions implemented in C
  • HiddenOnee
    HiddenOnee over 4 years ago in reply to Andrew Beckett
    Thanks Andrew.
    I still have a couple of questions. Since I'm new to Cadence, so they might be silly.
    1. Using "mmsim_genplugin" command can compile C file into the lib on SPECTRE. But I'm using Virtuoso, does it can be applied on Virtuoso as well?
    2. In the documentation, a script mmsim_genplugin should be installed, but I have no idea how I can install it with the command on the documentation.  Where should I type the command.
    3.Since I'm using a variadic function in C
    extern double inter(char* ctrl, char* file, ...)
    So I'm wondering how I can deal with the ... in verilog-a, should I just write
    import "CDS_VA_DPI" function real inter(string ctrl, string file, ...)?
    Thanks for your patience.
    Best Regards.
