  2. Mixed-Signal Design
  3. xrun simulation elaborates systemverilog real as binary
  • Subscribers 67
  • Views 11446
JayBee
JayBee over 4 years ago
Dear all,
I have a mixed signal SystemVerilog model which simulates fine when I run it from ADE.
I have real numbers as analog signals which I see as analog waveforms in simvision.
I guess this is a traditional AMS simulation, I have the connect rule ie cards set and all that stuff.
Now I want to use the xrun command line flow to simulate purely digital, since it is all verilog / systemverilog.
It does elaborate and simulate without errors.
However, all real types get mapped to binary types and I see only one bit output in the waveform.
I have tried xrun arguments -sv and -ams_flex. Both do work, but have the issue.
How can I get real numbers to be simulated as analog values in the xrun command line flow.
I fear that the question is really stupid, but I have been looking at RAKs and documents all over the forum and COS but cant't get it to work.
Thanks for all hints.
Cheers, Joachim
  • JayBee
    Just putting an ie_card.scs with the following did give errors "No master specified for instance ie" :
    amsd{
        ie vsup=1.5 discipline=logic vdelta="((`vsup)/10000000)"
