  2. Mixed-Signal Design
  3. dynamic selection totally freezes layout xl when there are...
  • Subscribers 67
  • Views 9575
dynamic selection totally freezes layout xl when there are many connectivity warnings
tdtg
tdtg over 4 years ago
Dymamic selection is a great tool for inspecting layout, but in Layout XL after Check it totally freezes with zillions of Markers - Connectivity. What can we do about this? Is there any option to limit Dynamic Selection display? Or it could be some deadlock with Net Tracer, which was running at the same time to probe some wires.
Screenshot below, frozen now several minutes
Version ICADVM20.1.64b.500.23 of Layout XL
    If Markers are set to not be visible in the palette (which is usually the default), they don't show up in the dynamic selection assistant. From your screen shot, I see they are marked as being visible in the Objects palette.
    I'm a little surprised there are quite so many markers, to be honest.
  • tdtg
    tdtg over 4 years ago in reply to Andrew Beckett
    Thanks, this will help. The reason we have so many markers is that most of our layout is not XL compliant (it is OLD) and when we run XL check with hierarchy we get zillions of errors.
    The other workaround is simply to delete these markers in cells before trying to run Dynamic Selection.
