  2. Mixed-Signal Design
  3. PSS/Pnoise for Correlated Double Samling
  • Subscribers 68
  • Views 5799
Ashwin Rebello
Ashwin Rebello over 4 years ago
I am analyzing a correlated double sampling system - specific to an image sensor. i am doing 2 conversions and removing the corelated noise in the digital domain by doing a subtraction. In my case the correlate noise comes from a sampled noise at the beginning of the cycle I am using for PSS.
PSS has converged properly, and I have analyzed the time domain signals in the PSS model and they make sense to me.
For Pnoise I have measured the noise (JEE) of the comparator triggering for both conversions and they make sense to me. I used Edge-Crossing for this analysis.
I have then proceeded to measure the time difference between the comparator triggering. using Edge-Delay for Pnoise. I expect the correlated noise which is common to both samples to disappear if I look at the difference. However, that is not the case.
I was wondering if anyone has tried this.
Ashwin
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago
    There is no pnoise/jitterevent mode to emulate correlated double sampling directly. A possible workaround is to subtract an appropriately delayed copy of the voltage (created by a vcvs with the td parameter set accordingly) from the sampled voltage in the schematic and by performing a pnoise simulation of this difference. However, we found that using the td parameter on the vcvs seems to stop multithreading from working; the additional threads were running idle in this case. We have filed CCR 2625594 for adding correlated double sampling to pnoise; if you ask Cadence Support to file a duplicate on your behalf, this might increase the chances of this being implemented one day.
  • Ashwin Rebello
    Ashwin Rebello over 4 years ago in reply to Frank Wiedmann
    for the pnoise analysis you are referring to above is it the "timeaverage" analysis
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to Ashwin Rebello
    No, it's the sampled analysis. Here is a simple example netlist where you can see the reduced noise at node rcdiff:
    simulator lang=spectre
    global 0
    R0 (rc 0) resistor r=1M
    C0 (rc 0) capacitor c=1p
    V0 (vsin 0) vsource type=sine freq=1G
    E1 (rcdel rcdiff rc 0) vcvs gain=1.0
    E0 (rcdel 0 rc 0) vcvs gain=1.0 td=500.0p
    iabstol=1e-12 temp=27 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
    sensfile="../psf/sens.output" checklimitdest=psf
    pss pss fund=1G harms=1 errpreset=conservative autotstab=yes
    + annotate=status
    pnoise pnoise start=1 stop=0.5G dec=20 pnoisemethod=fullspectrum \
    maxsideband=1 noisetype=sampled measurement=[pm0 pm1 pm2] \
    annotate=status
    pm0 jitterevent trigger=[vsin 0] triggerthresh=0 triggernum=1 \
    triggerdir=rise target=[rcdiff 0]
    pm1 jitterevent trigger=[vsin 0] triggerthresh=0 triggernum=1 \
    triggerdir=rise target=[rc 0]
    pm2 jitterevent trigger=[vsin 0] triggerthresh=0 triggernum=1 \
    triggerdir=rise target=[rcdel 0]
  • Ashwin Rebello
    thanks for your suggest and test case. I implemented the same concept in my test bench. I did a pnoise on the difference between the delayed sample and the current sample. The results make sense to me.
    I will try and back up your request to add corelated double sampling to pnoise which I think will be useful to many.
