  2. Mixed-Signal Design
  3. I am doing Beh Vs Schematic
  • Subscribers 69
  • Views 9903
sharifsharif
sharifsharif over 3 years ago
I am applying same digital inputs to both beh and sche , I need to convert that digital inputs into analog inputs, the inputs has 1 0 z x states.
Please tell me how to convert
    Andrew Beckett over 3 years ago +1
    Your question is rather lacking in detail. Is this with AMS Designer? In general, connect modules should get automatically inserted if there's a difference between the discipline of the driving net and…
    Your question is rather lacking in detail. Is this with AMS Designer? In general, connect modules should get automatically inserted if there's a difference between the discipline of the driving net and the circuit/model which should take care of doing the conversion if you've set up the simulation correctly. Or you could be asking about how to do this in a Verilog-AMS behavioural model. Or maybe a VHDL-AMS behavioural modal. Are you running in ADE or from the command line?
    Rather than giving a big explanation of every possible answer to what your question might be, please give some more details.
  • sharifsharif
    sharifsharif over 3 years ago in reply to Andrew Beckett
    Thanks for the reply,
    I am talking about interface elements (IE) in amsd block , that should be defines in the amscfg.scs file .
    The main aim of  that file is converting digital signal into analog signal.
    And also help with amscfg.scs related file information document
  • gulshan212
    gulshan212 over 3 years ago
    Hi this is Gulshan Negi
    I am a newbie here. Well, a ladder network of resistors or weighted input to a summing amplifier can be used to convert digital inputs to analog inputs. You can try this way and you can get results.
    Andrew Beckett over 3 years ago in reply to sharifsharif
    This is covered in the documentation for the ie statement in the Spectre AMS Designer and Xcelium Simulator Mixed-Signal User Guide.
