  2. Mixed-Signal Design
  3. Hierarchy dump into a file
  • Subscribers 67
  • Views 11656
RaghavendraN
RaghavendraN over 3 years ago
In continuation to the post https://community.cadence.com/cadence_technology_forums/f/mixed-signal-design/55546/skill-script-for-instance-extraction/1387720#1387720 , I would like to dump the hierarchy of the certain nodes of all the instances found using the command CCSPrintTable2(CCSFindCellInHier("search_name")) into a file. Lets say that instance has 5 terminal, I want to dump only 1 terminal node hierarchy into a file. Lets say instance named dff has 4 internal terminals namely clk,d,vdd,vss. But these terminals(clk,d,vdd,vss) aNotes_230118_235326 (1).pdfre connected at one level up with different names(clk_1,d_1,vdd_1,vss_1). I want to use one level up during hierarchial node dump into a file.
  • Saloni Chhabra
    Saloni Chhabra over 3 years ago
    Hi Raghavendra,
    Using the SKILL you have, the information you need about net names corresponding to instance terminals is already being printed in CIW. So, all you need is the same information to be written into a file? And on top of that, you'd like to narrow down this information by providing the cell name and terminal name as inputs to the script?
    Saloni
  • RaghavendraN
    RaghavendraN over 3 years ago in reply to Saloni Chhabra
    Yes. That is correct. for the attached pdf in initial thread, terminal name is ck. In the hierarchy that gets printed to the file, i want ck_1 to be the net name at the end of hierarchy sentence.
  • Saloni Chhabra
    Saloni Chhabra over 3 years ago in reply to RaghavendraN
    You just need to add or replace print commands in the code to direct the output to a file. e.g. I updated CCSPrintTable1 procedure to create a file called 'instinfo.txt'. fprintf is the command to write to a file.
    procedure(CCSPrintTable1(tbl)
    p = outfile("instinfo.txt")
    foreach(key1 tbl
      printf("Hier Inst: %s\n" key1)
      fprintf(p "Hier Inst: %s\n" key1)
    foreach(key2 tbl[key1]
      printf("%-5s Pin %-10L connected to Net %-10L\n" "" key2 tbl[key1][key2])
      fprintf(p "%-5s Pin %-10L connected to Net %-10L\n" "" key2 tbl[key1][key2])
    ) ;foreach
    ) ;foreach
    tbl
    close(p)
    Contents of instinfo.txt:
    Hier Inst: F1
    Pin "F1.PLUS" connected to Net "net3"
    Pin "F1.MINUS" connected to Net "net4"
  • RaghavendraN
    I was expecting contents of file like below:
    F1.net3
    F1.net4
    I I give arguments to the print1 procedure as PLUS, it should print below into a file:
    F1.net3
  • Saloni Chhabra
    All the information you need is already being extracted by the code - you just need to use the correct fprintf command to present it in a way you prefer.
      foreach(key1 tbl
      fprintf(p "%s.%s\n" key1 tbl[key1][key2])
      ) ;foreach
      ) ;foreach
      tbl
      close(p)
    This will return the format you asked for in a file called instinfo.txt. You still need to run the code the same way as before i.e. CCSPrintTable1(CCSFindCellInHier("dff"))
    -Saloni
