  2. Mixed-Signal Design
  3. SysVerilog bidirectional port with wreal nettype from c...
  • Subscribers 64
  • Views 10379
SysVerilog bidirectional port with wreal nettype from cds_rnm_pkg
HoWei
HoWei over 2 years ago
I was following this tutorial video https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009bfBiEAI&pageName=ArticleContent and created my own design. It uses the Cadence internal "$cged()" function to assign internal variables with the resolved net value of the declared nettype.
It will model 2 transmission gates, where each gate has 2 ports (A,B). The first gate has the nettype "wrealsum", whereas the second gate has the nettype "wrealmax".  This shall lead to different values on the nets, when the transimmion gate is enabled and driven with multiple drives (which is not the case in this example - here only 1 driver is connected):
import cds_rnm_pkg::*; //from dmsLib
`define resTyp1 wrealsum
`define resTyp2 wrealmax
module tb_wreal_TXRXdmy (
inout `resTyp1 InOut1A,
inout `resTyp1 InOut1B,
inout `resTyp2 InOut2A,
inout `resTyp2 InOut2B,
input logic control
//internal nets to store the external resolved value
`resTyp1 io1A;
`resTyp1 io1B;
`resTyp2 io2A;
`resTyp2 io2B;
initial begin
$cged(InOut1A, io1A); //$cged is required to store
$cged(InOut1B, io1B); //the resolved net value
$cged(InOut2A, io2A); //of the outside driving
$cged(InOut2B, io2B); //resolution function
end
//assign the internal signal to the other port
assign InOut1A = (control==1'b1) ? `wrealZState : io1B;
assign InOut1B = (control==1'b1) ? `wrealZState : io1A;
assign InOut2A = (control==1'b1) ? `wrealZState : io2B;
assign InOut2B = (control==1'b1) ? `wrealZState : io2A;
endmodule
The "control" is stimulated with a clock signal (20ns periode) and the input signals are applied to "InOutA1= 4.0" and "InOutA2=3.0". Both output signals "InOutB1" and "InOutB2" are open (not connected).
What I am expecting to see at the outputs is values toogling between the input values "4.0/3.0" and "Z".  But this is not the case.
Instead the output values at "InOutB1" and "InOutB2" are constantly showing the input signals "4.0/3.0".
Why is that - any idea ?
  • HoWei
    It turns out that the above code is correct - but the VIVA display tool does not distinguish between "wreal value" and "wrealZState".
    It both looks the same as a single line at 3.0.
    You only can see the difference if you user a vertical cursor and readout the values - then it toogles between "3.0" and "Z".
    I consider this a bug - it cost me more than a day to figure that out:
    Andrew Beckett over 2 years ago in reply to HoWei
    I'm a little surprised about this, since ViVA has had support for plotting wrealZstate and wrealXstate values since IC6.1.5 ISR8 (for 11 years). I just opened a database with X/Z value and it works fine:
    That said, I see a note in the documentation saying that there's a limitation with signals from ADE (the above was using the results browser). Maybe that's it.
    Anyway, I see you've filed a case 46684577 on this - I'll leave the team to handle it (this was a very, very quick answer as I am rather over-committed at the moment and can't spend much time on the forums).
  • HoWei
    HoWei over 2 years ago in reply to Andrew Beckett
    For completeness and FYI, I am using:
    - ICADVM20.10.160
    - Spectre 21.10.460
    - Xcelium 22.09.002
    But yes, the Cadence support team is working on it now.
  • HoWei
    Cadence support response is very slow on this topic.
    Did you use VerilogAMS simulation results in your above plots, or SytemVerilog simulation results with the "cds_rnm_pkg" as shown above ?
    I am not able to get the same results as you do - I was using the results browser as well.
    EDIT:
    I can confirm that in IC6.1.8.230 the display is showing the good X and Z states, as in your plot above.
    But in IC6.1.8.260 it is buggy and in ICADVM20.10.160.
