  2. Mixed-Signal Design
  3. Drive/monitor EEnet using virtual interface
  • Subscribers 67
  • Views 1872
jshaler
jshaler over 3 years ago
I am trying to write a UVM testbench for a block using EE_pkg::EEnet inputs/outputs, but it is not working. Is there something I'm missing for how to use interfaces with EEnet ports?
When I try to create an interface it does not compile:
import EE_pkg::*;
interface block_interface(input bit clk);
EEnet input_signal;
clocking driver_cb @ (posedge clk);
output input_signal;
endclocking
modport driver_mp (clocking driver_cb);
endinterface
I get an error:
xmvlog: *E,WOUPYR (block_interface.sv,70|22): As a temporary implementation restriction, unpacked structures nettype is not permitted in this context.
  • tpylant
    tpylant over 3 years ago
    I believe this issue has already been fixed in the latest releases. Which version are you using?
  • jshaler
    jshaler over 3 years ago in reply to tpylant
    I tried with 3 versions: 21.09.004, 22.09.004, and 23.01.071_agile
