  2. Mixed-Signal Design
  3. Are there predefined macros in XCELIUM (e.g. to be used...
  • Subscribers 67
  • Views 2089
Are there predefined macros in XCELIUM (e.g. to be used with 'ifdef )
HoWei
HoWei over 3 years ago
To write portable SV code (to be used with other vendors tools such as Synopsys or Mentor), I need to add an " 'ifdef 'else  " condition in order to include tool-dependent packages such as "cds_rnm_pkg::*".
I just learned that there is a default macro "XCELIUM" which can be used (and for the Synopys tool for example there is "VCS" defined):
'ifdef XCELIUM
   ...import Cadence packages ...
'elsif VCS
  ...import SNPS packages ...
'endif
1) Now I am wondering what other predefined macros are available, since i did not find this information when searching the XCELIUM user guide or on the Cadence website ?
2) Is there a more generic definition than "XCELIUM" available to indicate the Cadence tool-usage ? Because when the tool-name is changing (e.g. from INNOVUS to XCELIUM to ABCDEF)  then I would need to modify the code manually everytime.
