  2. Mixed-Signal Design
  3. Error in Running the simulation
  • Subscribers 68
  • Views 8942
Upendra Ch
Upendra Ch over 3 years ago
I am designing a delta-sigma modulator in which when I am running a standalone integrator and Flash ADC, it runs perfectly fine even though it shows warnings. Now when I am connecting the both and running the simulation, its shows an error and the simulation terminates. Iam attaching the error log with this query
    ShawnLogan over 3 years ago
    Dear Upendra Ch,
    I think you need to consider including more information to help anyone interested in providing some relevant suggestions. For example, I did not see the version of the Cadence tools you are using, nor did I find your simulation settings. I tried to view your schematic, which is helpful, but the resolution is poor and I could not make out the intervening components between your integrators.
    Nevertheless, when I did examine it as closely as I could, I noted that none of your integrators appear to have a ground connection. Is this intended? Missing ground connections can lead to convergence issues. I also could not make out some of the symbols between your integrators and am wondering if the elements I point to in an annotated version of a portion of your Forum post are AC coupling capacitors or multiple instances of voltage sources.
    Shawn
