  2. Mixed-Signal Design
  3. Measure performance metrics of SV-RNM vs VAMS models
  • Subscribers 67
  • Views 9076
naumel
naumel over 3 years ago
I am a student currently working on describing analog blocks with SystemVerilog using Real Number Modeling (RNM), which allows for discrete-time functional modeling of analog circuits and their behavior, enabling very fast event-driven simulation of the model. I already have Verilog-AMS models for these analog blocks, and since they are supposed to have much higher simulation costs, I would like to compare those to my SV-RNM models. Therefore, I would like to propose an approach to compare performance metrics between SV-RNM and VAMS models.
From what I could find on the net, it would be interesting to measure :
  • the overal “stopwatch” time from start to end (“real”)
  • the CPU time in user space of a single run (“user”)
  • the CPU time in kernel space of a single run (“sys”)
The thing is that, I am using SimVIsion(64) to run my simulations, and I have no idea how to measure those. Does anyone know how can I measure this ?
Also, I didn't find that much resources on this topic, so feel free to let me know if you have any information, documents, or even contacts that might help me.
Thanks for your help.
  • tpylant
    tpylant over 3 years ago
    SimVision will launch when you use the -gui option on the xrun command line. Remove that switch and add -status. The status argument will cause the simulator to print out runtime statistics at the end of simulation.
