  2. Mixed-Signal Design
  3. SImulation results visualization
  • Subscribers 68
  • Views 9229
mxm14
mxm14 over 3 years ago
When i launch a multicorner simulation, sometimes the history item says that almost all the sims are completed but i cannot visualize the results
Is there a way to refresh the "Results" page?
P.S. If I right click to the sim and i plot something, the results are showed. From the simulator log the sim has finished
  • mxm14
    I found the solution: I closed the simulation Tab and then I re-open it using View Result
  • Pirate King
    Pirate King over 3 years ago in reply to mxm14
    Hi mxm14, I get exactly the same problem many times;
    The log of the last 2 corners have finished but the screen will not update and the run counter is still showing 4/6 despite the logs show completion. I am not using any mmsim licenses anymore. As a last resort i did a "stop and resubmit" on the jobs but I wish I had read your post first! Could you expand on your solution? You mean close the maestro tab?
    I am using explorer not assembler
    Andrew Beckett over 3 years ago in reply to Pirate King
    The suggestion from the original poster only makes sense in Assembler, where you end up with different tabs for each history; then you can close the results tab and view the results again from the list of histories in the History tab of the Data View assistant.
    However, I would suggest two things:
    1. Make sure you're using LSCS in your job policy setup, as this is more robust about not losing messages sent from the child processes when Virtuoso happens to be busy. From your screenshot, you're using the older ICRP mode
    2. Use a recent hotfix of IC6.1.8/ICADVM20.1 (ideally the latest) - there have been many fixes over the duration of both release streams, including managing of results.
    There was a mechanism to force the status to done (added in ISR30), but this is for Assembler only; it's covered here: What’s New in Virtuoso IC6.1.8 ISR30 and ICADVM20.1 ISR30
