  2. Mixed-Signal Design
  3. Measure a branch current in Verilog AMS (Probe Command)
  • Subscribers 67
  • Views 8700
Devin Atkin
Devin Atkin over 3 years ago
My current setup for the model I'm writing is very rudimentary, but I want to simulate it with very idealized behavior before I start accounting for anything.
Currently I'm just accounting for the current through the ports OUT_N, and OUT_P. When I simulate it I can see the current flow; however, I want to see if over time not, just at the point the simulation stops. I think my issue is with my probe command which I grabbed awhile back with another module and have been slowly adjusting as needed.
probe -create -emptyok -all -shm -database waves {OUT_N}
This was what I had initially hopped should give me the current flowing in through the port as I've set it to 3.3V which I can see fine; however, I cannot see the current flow into the port of the Verilog AMS module. I've tried manually defining branches, I've tried to use the inhconn_signal to try and get the flow with that. I feel I'm lacking something fundamental.
Here's my testbench code
`include "disciplines.vams"
`include "constants.vams"
module PIXEL_TB();
electrical SINE_IN, OUT_P, OUT_N;
electrical vdd, gnd;
ground gnd;
PIXEL DUT (.SINE_IN(SINE_IN),.I_OUTP(OUT_P),.I_OUTN(OUT_N),.gnd(gnd));
parameter real carrier_freq = 1000000, ampl=1.0, offset = 1.0;
analog begin
    V(vdd,gnd) <+ 3.3;
    V(OUT_P,gnd) <+ 3.3;
    V(OUT_N,gnd) <+ 3.3;
    //Feed input sine
    V(SINE_IN,gnd) <+ ampl * sin(2.0*`M_PI*carrier_freq*$abstime);
    V(SINE_IN,gnd) <+ offset;
    // Tie the outputs to
    $bound_step(0.05/carrier_freq);
end
endmodule
I'm just getting started with using Verilog AMS for my designs so I apologies in advance if this question is ridiculously obvious to some. I feel I'm being stymied by my own inability to figure what exactly to google.
