  2. Mixed-Signal Design
  3. bus values in corners
  • Subscribers 68
  • Views 8113
greywanderer
greywanderer over 3 years ago
I am trying to track the value of a bus over corners in adexl. Following are the relevant definitions
bus = getData("/a<0:9>")
bus_val = value(bus 1n)
What I see in the results output is a waveform instead of a value. The waveform seems to be a "family" dependent on various simulation parameters and corners.
Is there a simple way to get the value of the bus reported over the different corners in adexl?
Thanks much!
    ShawnLogan over 3 years ago
    Dear greywanderer,
    Did you try print( value(bus) 1n) )?
    Shawn
  • greywanderer
    greywanderer over 3 years ago in reply to ShawnLogan
    Hi Shawn,
    Setting an output in adexl to print(value(bus 1n)) results in an "eval err".
