  2. Mixed-Signal Design
  3. using "range" in the "Spec" column for the ADEXL Output...
  • Subscribers 68
  • Views 4351
using "range" in the "Spec" column for the ADEXL Outputs
greywanderer
greywanderer over 3 years ago
What is the format to set a spec as a range of values? The documentation on Assembler seems to suggest this,
But setting the spec to(eg.) -> 3 4 is not accepted by assembler.
Thanks!
    ShawnLogan over 3 years ago
    Dear greywanderer,
    When you select "range" as the specification type for an Assembler output, you will be presented with two entry boxes - one for the minimum and one for the maximum limit. In your case, you would enter 3 and 4 in the leftmost and rightmost entry boxes respectively. An example is shown below.
    Perhaps you entered both the 3 and 4 as a single specification? Or perhaps I totally misunderstood your question?
    Shawn
  • greywanderer
    greywanderer over 3 years ago in reply to ShawnLogan
    Hi Shawn,
    I completely missed the second box. It works as you say it should.
    Thanks!
    ShawnLogan over 3 years ago in reply to greywanderer
    Dear greywanderer.
    Excellent! it is easy to overlook these things. I am just happy to read you are up and running again - good luck!
    Shawn
