  2. Mixed-Signal Design
  3. Is it possible to netlist a cross event in Verilog-A?
  • Subscribers 69
  • Views 10091
twix232
twix232 over 3 years ago
I'm trying to implement a prescaler block in verilog-a. The block should trigger a certain behavior when both signal1 and signal2 have rising edges.
// when a signal1 is in rising edge
@(cross(signal1 , 1)) begin
    // check also when signal 2 is in rising edge
    // but this checking should be second in priority
    // which means when signal1 is in rising edge
    // go check if signal 2 is in rising edge
    @(cross(signal2 , 1)) begin
        do something
    end
end
I have been searching for ways to create netlist-like events to achieve this functionality in Verilog-A, but I couldn't find any similar examples. Can you provide guidance on how to approach this situation and implement the desired behavior?
    ShawnLogan over 3 years ago +2
    Dear twix232, twix232 said: I'm trying to implement a prescaler block in verilog-a. The block should trigger a certain behavior when both signal1 and signal2 have rising edges. I think you basically…
    Dear twix232,
    I think you basically need to set a flag when signal1 undergoes a rising edge and then use the flag in the cross statement for signal2. The cross event syntax includes an "enable" input. When the value of "enable" is non-zero, the cross expression is evaluated. However, if it is zero, it is not evaluated. Hence, if you set your flag to zero and then to, say, 1 when signal1 undergoes a rising edge, the cross event for signal2 will only be evaluated after signal1 undergoes a rising edge. Of course, if you have more than one rising edges of signal1 in your simulation time and want to detect a second signal2 edge, you will need to reset the flag to 0 after the cross event for signal2 occurs.
    An example may be found at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009MpctUAC&pageName=ArticleContent
    I hope this helps twix232.
    Shawn
    • Vote Up +2 Vote Down
  • twix232
    twix232 over 3 years ago in reply to ShawnLogan
    Helpful answer thank you
    ShawnLogan over 3 years ago in reply to twix232
    Dear twix232,
    Great! Thank you for letting us know you made some progress!
    Shawn
