  2. Mixed-Signal Design
  3. Manual or Document about the bmslib
  • Subscribers 67
  • Views 8488
xiaolaba
xiaolaba over 3 years ago
Is there any manual or document about the bmslib? I try to use the comparator veriliga model in this library. But fully understanding it is not easy even with the code note.
    No, the only documentation is either the README file within the library itself (which is just a description of what each model is for) and the comments at the top of each model or by the parameters. Not sure which model you are talking about because there are several comparators in that library.
