  2. Mixed-Signal Design
  3. runams hangs
  • Subscribers 68
  • Views 9439
runams hangs
Continuum
Continuum over 3 years ago
I don't know what has changed, but runams has started hanging on me. This is killing my verification flow. This now happens every time I use runams.
I run the following command:
runams \
    -cdslib ./.tmp.cds.lib \
    -irunopts '-nocopyright -linedebug -define TESTBENCH=sh_tb' \
    -modelincdir \
    /home/continuum/src/verif/av/tests/case33oa/../design-oa \
    -modelpath 'models.scs(tt):anamodels.scs(tt)' \
    -netlisteropts amsPortConnectionByNameOrOrder=name \
    -log ./.sh.mvm33.netlister.log \
    -lib mylib \
    -cell sh_tb \
    -view mvm33 \
    -netlist all
runams runs and generates the netlist. It then prints a prompt and waits for commands.
Running netlist assembly..
End netlisting Aug 25 12:50:35 2023
INFO (AMS-1254): AMS UNL netlisting has completed successfully.
      ...successful.
create cds_globals...
At this point it hangs, waiting forever.  I can type commands and it will respond, but I cannot find a command that causes it to terminate.  I have tried quit, quit(), exit, exit() and ctrl-D.  quit and quit() result in error messages. ctrl-d is ignored.  exit and exit() causes program to hang, this time without the command prompt.  Even ctrl-C will not kill the program.  I have to use ctrl-\.  All of this means I can no longer use runams in a script.
Any ideas on what might be causing this or how I can resolve this issue?
  • Continuum
    Continuum over 3 years ago +1
    Oh, I am using the following versions: IC_06.18.330, SPECTRE_23.10.063, XCELIUMMAIN_23.03.005 I then switched to IC_23.10.010 and got the same result. Switching to XCELIUMMAIN_20.09.002 resolves the…
    Andrew Beckett over 3 years ago in reply to Continuum +1
    That's very odd. It sort-of looks as if it's something causing it to display an invisible dialog box at the end which then can't be pressed - but the fact that the interactive prompt appears is a little…
  • Continuum
    Continuum over 3 years ago in reply to Andrew Beckett +1
    The > is a prompt. I can type a command and it will respond and then provide another prompt. I will try RUNAMSDEBUG.
  • Continuum
    Switching to XCELIUMMAIN_20.09.002 resolves the runams problem.  Ironically downgrading just xcelium causes the simulator to hang after the simulation.  However, using the latest version of IC while using 2020 versions of both Spectre and Xcelium does seem to work.
    That's very odd. It sort-of looks as if it's something causing it to display an invisible dialog box at the end which then can't be pressed - but the fact that the interactive prompt appears is a little strange (I wonder whether it's really interactive or just showing ">").
    I need to check with the specific versions you're using - I was trying but with an older version of XCELIUM (I'd not got anything beyond XCELIUM2203 installed on my local machine), so I'll check that later.
    If you set this:
    setenv RUNAMSDEBUG YES
    then it will keep the virtuoso log file from the slave virtuoso session in the runams run dir (under a dot dir something like AMSexample-top-config/.rams_virtuoso_temp_107671/ ) maybe that will give a clue?
  • Continuum
  • Continuum
    Continuum over 3 years ago in reply to Continuum
    I set RUNAMSDEBUG and re-ran the netlisting and there was nothing in the log file that provided any help.  Though I noticed one thing that surprised me.  When the process has hung, it is taking 100% of a CPU.  So it is not simply waiting passively for another command.
