  2. Mixed-Signal Design
  3. PDF files in library manager
  • Subscribers 67
  • Views 8824
Continuum
Continuum over 3 years ago
Is it possible to deposit PDF files into a design repository and then open and view them from the library manager?
Some one told me that it is possible if I use document.pdf as the filename and set the master.tag accordingly.  But that does not seem to work for me.
Is there a plugin I must install?
    Andrew Beckett over 3 years ago +1
    It's not a viewType registered as standard, but this article explains how to add support to the data registry: DFII: How to register a pdf, openOffice and an html view in the Virtuoso Design Environment…
  • Continuum
    Continuum over 3 years ago in reply to Andrew Beckett +1
    Thanks Andrew. That apnote is dated and a bit of a mess, but I was able to use it to work through the issues I was having. For any that follow me, here is what I ended up doing to install zathura as a…
    Andrew Beckett over 3 years ago in reply to Continuum +1
    Continuum said: That apnote is dated and a bit of a mess Completely agree. This is one of those articles that whenever I see it I want to rewrite it completely and do a better job of explaining it. I…
  • Continuum
    Thanks Andrew.  That apnote is dated and a bit of a mess, but I was able to use it to work through the issues I was having.  For any that follow me, here is what I ended up doing to install zathura as a PDF viewer in the library manager.  Zathura is a PDF viewer that supports Vim-like keystroke navigation that is a very efficient way to view a file.
    First I needed to add a file that introduces zathura to the registry.  I placed that file here: $CDSHOME/share/cdssetup/registry/data/zathura.reg
        // Data Register file for adding pdf view
        DataFormat Zathura {
            Pattern=document.pdf;
            Preferred_Editor=Zathura;
            dfII_ViewType=document;
            Co_Managed=document.pdf master.tag ;
        ViewAlias {
            document=Zathura;
        Tool Zathura {}
    Then, I needed some skill code, which I placed in ~/.cdsinit so that was loaded automatically:
        /* Add PDF view an associate it with Zathura viewer */
    procedure(
    openPdfDataTrigger(argList)
    let(
    mode(getq(argList accessMode))
    libName(getq(argList libName))
    cellName(getq(argList cellName))
    viewName(getq(argList viewName))
    fileId
    fileName
    if(fileId = ddGetObj(libName cellName viewName "document.pdf" nil "r") then
    fileName = strcat(
    ddGetObjWritePath(ddGetObj(libName cellName viewName))
    "/document.pdf"
    system(sprintf( nil "/usr/bin/zathura %s &" fileName))
    t
    ; Dummy trigger functions
    procedure( CCSpdfAppTrig(argL) t )
    procedure( CCSpdfEnableTrig(@optional argL) t )
    ; Registration function
    procedure(
    CCSpdfRegister()
    deRegApp(
    ?appName "Zathura"
    ?appTrigger 'CCSpdfAppTrig ; Dummy function
    ?dataTrigger 'openPdfDataTrigger
    ?enableTrigger 'CCSpdfEnableTrig ; Dummy function
    ?viewType "document"
    ?widgetType "none"
    ; Register the triggers
    CCSpdfRegister()
    envSetVal("graphic" "viewNameToTypeList" 'string "document document.od* pdf")
    Finally, I manually created a cellview for my PDF file. The file must be named 'document.pdf' and must have a corresponding master.tag file file. Then simply restart virtuoso.
    Completely agree. This is one of those articles that whenever I see it I want to rewrite it completely and do a better job of explaining it. I can't get the original author to do it since they're no longer around. Maybe I'll have a chance at some point...
    Anyway, thanks for your clear outline of what you did to make this work.
