  2. Mixed-Signal Design
  3. Simulate N-bits input configuration in transient
  • Subscribers 67
  • Views 8924
IKIF
IKIF over 3 years ago
Hi.
I simulate transient and during the simulation I want to change N-bit configuration input.
How I do that without using N-sources with defining delays/periods/..  in each source ?
Thank you in advance.
    Andrew Beckett over 3 years ago in reply to IKIF +1
    I suggest you use a Vector File in that case. This is specified via Setup→SImulation Files→Vector Files in ADE, and the syntax is covered in the Spectre User Guide (<SPECTREinstDir>/doc/spectreuser/spectreuser…
    Which simulator are you using?
  • IKIF
    IKIF over 3 years ago in reply to Andrew Beckett
    Transient.
    I want to sweep configuration and to see response .
    IKIF said:
    Transient.
    That wasn't what I asked. You just repeated what you'd said in your original post.
    Let me spell it out (I would have thought "which simulator" was pretty clear though). Are you using spectre? Are you using AMS Designer? Are you using some other simulator? If so, which?
  • IKIF
    spectre
    I suggest you use a Vector File in that case. This is specified via Setup→SImulation Files→Vector Files in ADE, and the syntax is covered in the Spectre User Guide (<SPECTREinstDir>/doc/spectreuser/spectreuser.pdf or use <SPECTREinstDir>/bin/cdnshelp (or cda if using the latest version of Spectre) and accessing it that way). It's in Appendix D of the version I was looking at, headed Digital Vector File Format.
  • IKIF
    Than you very much , works perfectly.
    The Spectre User Guide so difficult to understand , found some good example.
