  2. Mixed-Signal Design
  3. how to see value of Verilog variable in ams batch mode simulation...
  • Subscribers 67
  • Views 10829
how to see value of Verilog variable in ams batch mode simulation?
wangyunxin
wangyunxin over 2 years ago
For example, I want to look at the values of the variables data_to_dut and data_from_dut in the diagram, but these two variables are not input and output of the Verilog module, but a variable within the Verilog code. (If they were inputs or outputs, I would be able to send their waveforms to Maestro on the schematic and plot them). So, how should I send these two variables to Maestro under the batch mode simulation?
  • tpylant
    tpylant over 2 years ago
    You could use SimVision which would have visibility into the Verilog code.
    Tim
