  2. Mixed-Signal Design
  3. SOA checks across multiple PVT runs
  • Subscribers 68
  • Views 11584
NewScreenName
NewScreenName over 2 years ago
Hi all,
I am simulating a design over different PVT and design variables and need to check SOA for all of them. Currently I write the checks output on a file which I can then pass to a foundry provided script which will dothe work of checking through all of them. The way I am doing it is this:
However in this way I always get only one output file.
Is this file the one corresponding to the last run of the various PVT/design variables which finished running?
And how can I get one separate file for each of them?
Thank you
Best regards
    Andrew Beckett over 2 years ago +1
    If you don't give a full path (e.g. just "out_file.soa") then it will be written into the netlist directory (I think - might be psf, but I think it's the netlist - don't have time to test right now). That…
    ShawnLogan over 2 years ago in reply to NewScreenName +1
    Dear NewScreenName, NewScreenName said: How could I have a python script to run automatically to all the out_file.soa generated in the different directories after the simulation finished? I may be…
    If you don't give a full path (e.g. just "out_file.soa") then it will be written into the netlist directory (I think - might be psf, but I think it's the netlist - don't have time to test right now). That means you'll get one per sweep point.
  • NewScreenName
    NewScreenName over 2 years ago in reply to Andrew Beckett
    it's the netlist directory indeed.
    And if possible, any way an ocean script could read the output of such script (a string) to directly print it in the ADE assembler results?
    Thank you
    Best regards
    Dear NewScreenName,
    I may be able to help a bit with this. I assembled a shell script that will traverse an Assembler database and run a python script on each netlist instance of the file "out_file.soa". I do not know what type of output your python script produces, so I wrote an example schell script that takes a filename as an argument and prints the contents of the file. I created a sample Assembler database as "Interactive.1" with 4 corners and placed an different "out_file.soa" i each netlist directory. The sample python script is called "print_soa_file.py" and the script name is "run_python_script_sml_120423.sh'. The shell script has 3 arguments:
    1. The path to the simulation results (i.e., location of Interactive.X directories)
    2. The Interative.X number (i.e., the numeric value of X)
    3. The name of the python script in the current directory
    In the example I included, the runline is also included and contains the single line:
    $ cat runline
    run_python_script_sml_120423.sh /Users/sml/Desktop/python_script_scan_netlist_dir/myhome/simulation 1 print_soa_file.py
    The script, example python file, example simulation directory, and a README file are all contained in the attached compressed zip directory.
    I hope this is useful NewScreenName.
    An ocean script may also be used to navigate the Assembler database. I have included a sample ocean script with comments for one to modify for their use in several Forum posts.
    Shawn
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/92/python_5F00_script_5F00_scan_5F00_netlist_5F00_dir.zip
  • NewScreenName
    NewScreenName over 2 years ago in reply to ShawnLogan
    Thank you very much!
    Of course! I just hope the instructions make sense to you. Let me know if you have any questions or issues NewScreenName.
    Shawn
