  2. Mixed-Signal Design
  3. Changing effective CDF parameters using skill code
  • Subscribers 67
  • Views 9218
Me Daniel
Me Daniel over 2 years ago
I would like to change the effective CDF parameters of a PDK. There are two ways know to me: SKILL and the CDF GUI, setting the CDF layer to effective and than changing the parameters works fine in the GUI. However this approach is rather time consuming each time I start Cadence. I would like to change the parameters using SKILL, currently I'm running into some issues.
I would like to know what I have missed, where my code is in error. I hope you can help me.
But first the skill code:
;; procedure copied from Cadence website and slightly modified it for my use, due to the fact support.cadence.com/.../ArticleAttachmentPortal
procedure( CCSsetCDFdefValue(cdfid paramid defval)
    let( (store)
        print("param found")
        ;; store the current parameter settings as a disembodied
        ;; property list that contains pairs of the property name
        ;; and value
        store = cons(nil paramid~>??)
        ;; delete the original parameter
        cdfDeleteParam(paramid)
        ;; re-create the parameter as it was except for the
        ;; default value which is passed in
        cdfCreateParam(cdfid
        ?name          store->name
        ?type          store->paramType
        ?defValue      defval
        ?units         store->units
        ?parseAsNumber store->parseAsNumber
        ?choices       store->choices
        ?prompt        store->prompt
        ?use           store->use
        ?display       store->display
        ?editable      store->editable
        ?dontSave      store->dontSave
        ?callback      store->callback
        ?storeDefault  if(store->storeDefault "yes" "no")
        ?parseAsCEL    store->parseAsCEL
        ;; save the whole CDF
        cdfSaveCDF(cdfid)
    ); let
); procedure CCSsetCDFdefValue
library = "PDK_lib"
foreach(cell ddGetObj(library)~>cells
    ;;code line to select the effective CDF
    cdfid=cdfGetCellCDF(ddGetObj(library cell~>name))
    ;;code line to select the base CDF
    ;;cdfid=cdfGetBaseCellCDF(ddGetObj(library cell~>name))
    ;;code line to select the user CDF
    ;;cdfid=cdfGetUserCellCDF(ddGetObj(library cell~>name))
    if(cdfid
    then
        ;; cdfFindParamByName(cdf "paramName") does not work and results in errors see below
        foreach(param cdfid~>parameters
            if(strcmp(param~>name "param1") == 0
            then
                ;param~>value = "None"
                param~>defValue = "None"
            if(strcmp(param~>name "param2") == 0
            then
                CCSsetCDFdefValue(cdfid param nil)
        cdfSaveCDF(cdfid)
Selecting the base CDF is not possible due to the fact that de PDK for me and in general is not editable.
selecting user does not give any results, the user CDF is empty it appears...
selecting the effective CDF the case I would like gives me the following:
*WARNING* Invalid effective CDF data type cellData.  Effective CDF cannot be modified
And the result is no changes to the effective CDF, I don't understand why, because to GUI methodes works fine
cdfFindParamByName(cdf "paramName") :
*WARNING* Can't modify attributes of effective CDF parameters.
Kind Regards and thank you for you help,
Daniel
