  2. Mixed-Signal Design
  3. Add verilog configuration to a mixed signal simulation with...
  • Subscribers 67
  • Views 7827
Add verilog configuration to a mixed signal simulation with config view
moosbru
moosbru over 2 years ago
I have a digital block (SV-RTL) whith a verilog config which I can simulate in a pure digital simulation using
xrun -top myrtl -compcnfg myconfig.sv
where myconfig.sv looks like:
config myrtl
  design worklib.myrtl;
  default liblist worklib ...;
  cell mycell liblist speciallib;
endconfig
This works fine for a pure digital simulation.
For AMS, myrtl is compiled into a library mylib using -makelib, provided to the simulator using -reflib, and there is a  verilogAMS wrapper myrtl_wrapper which instantiates myrtl.
Now I want to run an AMS simulation of a schematic ("mytop") containing an instance of myrtl_wrapper.
Hence, I have a testbench cell ("tb_mytop") with a config view ("config_ams") for simulating an instance of the cell (schematic) "mytop". The configuration config_ams is used to select the VerilogAMS view for the myrtl_wrapper instance.
  • How can I now make sure in my AMS Simulation of "mytop" is using mycell from speciallib?
My first intention was to add a config, but then the questions arises, how that config should look like (e.g. name of config, design in config), since I expect that the config should be for the top, which is actually a schematic in this case.
According to the xrun.log -top is <vrituoso_library>.<testbench cell>:schematic_ams
But I did not suceed in creating and using the correct config (-compcnfg) so far.
  • Or maybe there is an alternative way of ensuring that mycell from speciallib is taken besides creating a configuration?
Thank's in advance for any help.
Best, moosbru
  • moosbru
    Meanwhile, I found a solution to overcome the problem.
    I did not succeed in using a configuration, however, instad of using the configuration, I used
    `uselib lib=speciallib
    ... code ...
    `nouselib
    in myrtl, to force myrtl to force the instance of myrtl to be bound to speciallib.
    An alternative solution, to use -binding option, did not solve the issue since it works to direclty bind an instance to a library, however, based on my experiments, -binding does not inherit the binding to the descendents of the bound unit, which was neccessary in my case due to naming clashes of primitives withing multiple libraries.
