  2. Mixed-Signal Design
  3. rcnetwork_* in noiseSummary
  • Subscribers 67
  • Views 4580
BillatBRCM
BillatBRCM over 2 years ago
The noiseSummary from SpectreX .noise simulation shows many contributors as /rcnetwkrin_*.  These instances probably are converted from the R and C parasitics in the spf file.
To optimize the noise from rcnetwork_*, need to know which devices in the spf file they are converted from.
- Is there any way to find the mapping of /rcnetwork_*?
- Or is there any way to make noiseSummary report the original R, C elements in the spf file?
Below is part of the noiseSummary showing contribution from /rcnetwork_* and the option use in .noise simulation.
Thank you for any reply.
NoiseSummary:
Device   % Of Total   Inp Ref Noise    Param    Noise Contribution
/rcnetwork_  91   4.71   2.41197e-08   total   7.66259e-06
                                                           rn   7.66259e-06
/rcnetwork_  90   4.58   2.35393e-08   total  7.45786e-06
                                                           rn   7.45786e-06
/rcnetwork_  8   4.04    4.35474e-07   total   6.5794e-06
                                                           rn   6.5794e-06
/rcnetwork_1006   2.12   1.08516e-08   total   3.45633e-06
                                                          rn   3.45633e-06
Command in spectre input file for noise simulation:
noise ( vop von ) noise start=100k stop=60G dec=157 \
iprobe=Itb_stim.Vac_stim annotate=status
-Bill
    Bill,
    See What are the *_RCNet_* devices in the output noise summary/results after the post layout simulation?
  • BillatBRCM
    BillatBRCM over 2 years ago in reply to Andrew Beckett
    Thank you Andrew,
      I found the parasitic devices corresponding to the rcnetwork_*.  Then document is very helpful.  Appreciate your help!!
    Bill
