  2. Mixed-Signal Design
  3. Xcelium AMS flow do not support 32bit
  • Subscribers 67
  • Views 6848
stones
stones over 2 years ago
I have to run my AMS simulation (xrun) in 32 bit  mode.
The reason for this is that the c-code which I need for simulation is only prepared only for 32 bit.
Is there any solution for this?
amsspice: WARNING: 32bit executable version of "amsspice" not found... the 64bit version will  be used instead
Should I go to an older version or irun ?
BR
Juergen Weber
    Why can you not do 64-bit compilation of the C code? Surely that's the easiest solution...
    Spectre has not supported 64-bit simulation for some time - and given that Mixed-Signal simulation uses the version of Spectre in the path rather than an integrated version of Spectre for some time, you'd have to switch back to a pretty old Spectre (I forget when 32-bit was dropped).
